RC10B4.1 FT/WC
Old 11-29-2011 | 06:37 PM
  #7951
SoccerSting's Avatar
Originally Posted by xtraman122
Front hingepin brace, maybe shock standoffs.
Have you broken the aluminum hingepin brace?
SoccerSting is offline
Old 11-29-2011 | 06:40 PM
  #7952
xtraman122's Avatar
Nope, just giving an idea, thought it would look good.
xtraman122 is offline
Old 11-29-2011 | 06:42 PM
  #7953
Originally Posted by bds81175
Any screws threaded into aluminum should have threadlock on them. The long screws that hold the sides of the transmission together and thread into the motor plate should definitely have thread lock and shouldn't be tightened too far or the transmission will bind. You will be able to feel the binding if its present on your car while tightening and loosening the screws. Also the screws on the bottom side of the steering rack shouldn't be too tight either. The bell cranks should flop back and forth loose. If you have a metal geared servo you can glue the steering rack. The larger of the two bell cranks is the servo saver. When you pull the bell crank apart, there is a nut on top with the bearing in it. This nut compresses a spring that holds the two halves of the bellcrank together until force is applied (impact with a marshals hip, for example ). Take it all apart and put some CA on the contact points between the two halves so they can't rotate against each other. Reassemble it with the nut, washer and spring. It definitely makes the buggy and especially the trucks feel more direct when cornering. Hope this helps.
Thanks a bunch!
Any clue about the capacitors?
The other night I noticed someone with a stock t4.1 that had soldered two small capacitors (at least that's what they looked like) just in front of the ESC on the battery wires. I've never seen this before and am wondering what the advantage is? Capacitors are dirt cheap and if it helps I'd be willing to purchase those immediately.
Hinecken is offline
Old 11-29-2011 | 07:40 PM
  #7954
Default new parts
yes i can do the usual stuff and i am working getting this stuff done for cheaper price then the competitors a more reasonable price like it should be.and i was kinda wanting to know if there are any parts that people have thought of that would like it to be in titanium or coated to make less friction. maybe something along the lines of hardened titanium out drives so they dont wear out so stinkin fast just ideas and thoughts every one is appreciated thankslets make these cars better
manoce is offline
Old 11-29-2011 | 07:44 PM
  #7955
Default new parts
would anybody buy aluminum or titanium shock caps with the bleed hole and screw?
manoce is offline
Old 11-29-2011 | 08:24 PM
  #7956
Fellow drivers,
I created a quick html doc for my kinetic setup as the one that Novak was not the easiest for me to use. Also, I'm working on a spring chart that people can just d/l to their phone or whatever easily. They're both listed here: http://b6pilots.com/OR/ I keep the Kinetic file on my phone for quick reference and plan to do the same for the springs. If you guys would like to see anything added, just let me know and provide the numbers if you can. Thanks
ufoDziner is offline
Old 11-29-2011 | 10:50 PM
  #7957
Aluminium - maybe.
Titanium - what on earth for?
LD50 is offline
Old 11-29-2011 | 11:04 PM
  #7958
Do any rubber shock boots (Losi, Durango, Xray...) fit the standard V2 shocks?
LD50 is offline
Old 11-29-2011 | 11:12 PM
  #7959
Registered User
I had the same issue, even the Ae nut driver wouldn't quite cut it. I ended up taking a Dynamite nut driver and grinding the OD down a little bit to get it to fit better.
I had the same issue as well. I spoke with Dave at DE and he is aware of the issue and trying to come up with a solution. I found that the AE 11/32 driver was tight but did work
Ryno B4.1 is offline
Old 11-29-2011 | 11:48 PM
  #7960
Wild Cherry's Avatar
Originally Posted by Double Dee
I can Say Mike and lukes car look very good with the losi springs.
Those 12m BB losi's are becoming a "must have" or go slow improvement kind of thing .....
I broke me personal best tonight by quite a bit with um...
Bet U availability will be running low after next week ....
Timmahhh
I don't really know exact details or the technicals about these springs, just trying my best to inform how the Losi BB springs perform and feel ..
Skengines
Use Losi BB spring cups , recommend silver ft & Pink rear.
Aniznik
I don't have access to a chart that includes the new Losi BB spring ..
Maybe some one could be nice & post if they know of a chart ....
Wild Cherry is offline
Old 11-29-2011 | 11:50 PM
  #7961
T-BirdJunkie's Avatar
Timmahhh
Skengines
Aniznik
Obviously the springs are different, but the coding is exactly the same, color-to-rate for front and rear.
T-BirdJunkie is offline
Old 11-29-2011 | 11:51 PM
  #7962
never mind
Old 11-29-2011 | 11:54 PM
  #7963
Nevermind what? Were you about to doubt ThunderbirdJunkie again?
Old 11-29-2011 | 11:57 PM
  #7964
No !!
Just forgot to tell you to no excuse's for you with your new ride ...
Old 11-30-2011 | 12:06 AM
  #7965
No !!
hehe
ThunderbirdJunkie's excuse is his piss poor driving, always has been, always will be
BTW, picked up the spring cups and collars to put the springs on the car...forgot to get the springs
