Hot Bodies TCX
Old 10-20-2011, 09:40 PM
  #3796
hi-tech-redneck's Avatar
Originally Posted by olhipster1
who has the lipo chassis in stock? in the U.S.
thanks
hotboddies online has them now,haven't seen them anywhere else avalible yet here in the usa at least online i have been checking every couple of days since the new parts were announced! there 99.75$ but the shipping is free fedex
hi-tech-redneck is offline
Old 10-22-2011, 08:15 AM
  #3797
bigz's Avatar
Originally Posted by Korey Harbke
They make it so the servo must travel further to give full steering throw. It increases resolution and makes the steering feel more precise and smoother. Similar to the way the tamiya knuckles effect our car, but these are designed specifically for our car and fit properly.
-Korey
Edit... I thought you meant the steering blocks and knuckles. The wider suspension blocks make the front end have a higher roll stiffness. Usually wider suspension blocks give you more initial turn in, and a little less steering through the middle and exit of the corner.
If it gives more steering throw, what will happen if the rear is replaced with the 1 block?
bigz is offline
Old 10-23-2011, 01:27 PM
  #3798
Korey Harbke's Avatar
Trader Rating: 13 (100%+)
It's not actual steering throw. As long as you re-setup your radio, it should be the same. I'm talking about an actual driving characteristic.
As for the rear of the car, I honestly have not tested this for a VERY long time (like when I ran a Tamiya Evo 3 days). The roll stiffness would be slightly higher, so I'd assume the car might feel a little more planted in quick transitions, but through the middle of the corner it might have less grip.
But, it's something you'll just have to try for yourself. Let us know what you find! Hiro might be able to pop in and give some insight as well. I'm sure he's tested it at some point.
-Korey
Korey Harbke is offline
Old 10-23-2011, 06:18 PM
  #3799
bigz's Avatar
-Korey
Thanks....will definitely try it out this weekend......
bigz is offline
Old 10-24-2011, 11:38 AM
  #3800
Default Parts needed
Hi
have been away from racing since spring this year , had just bought a TCX at that time , but can understand that there have been some new parts. Can anyone help me with a "need" list , so I can get my TCX up to date and fully race ready
thanks in advance
Mike/sweden
HB-forever is offline
Old 10-24-2011, 05:42 PM
  #3801
Mickey Silver's Avatar
^^^^ +1
Just new to this chassis and class really. Driven lots of other classes on/off road. In addition to whats suggested for performance upgrades what is suggested for durability upgrades. I am having breakage issues with the front end mainly stock alluminum axles and knuckles.
Tim
Mickey Silver is offline
Old 10-24-2011, 11:35 PM
  #3802
spring71's Avatar
Smile
New spec r TCX parts are arrived at TQ
Click here
FYI, Thanks.
spring71 is offline
Old 10-25-2011, 11:50 AM
  #3803
AGNO's Avatar
Andy Moore wins the BEIJING 2011 INVITATIONAL RACE
1 Th Andy Moore HB - TCX
2 Th Ben Cosgrove - HB TCX
3 Th Stefan Chodzynski - HB TCX
5 Th Wang Hai Fang - HB TCX
Andy's car
AGNO is offline
Old 10-25-2011, 12:16 PM
  #3804
ShaunMac's Avatar
Ronald looks bummed in that pic.
What transponder is in Andy's car? It looks bigger than a regular MRT.
ShaunMac is offline
Old 10-26-2011, 01:53 PM
  #3805
Default Andy's bumper
Do we know what foam bumper andy is using???
Matt W is offline
Old 10-26-2011, 01:56 PM
  #3806
k_bojar's Avatar
Trader Rating: 30 (100%+)
looks like the one RIDE makes for the TCX - at least it looks like the RIDE one i have on mine
k_bojar is offline
Old 10-26-2011, 09:35 PM
  #3807
sprintcarracer's Avatar
Trader Rating: 26 (100%+)
Anyone used the dcj front drive shafts? How long are they?
sprintcarracer is offline
Old 10-27-2011, 01:27 AM
  #3808
AGNO's Avatar
They are 44mm long, I tried, but I prefer the 46mm steel CVD, offer better and more consistent traction.
The steel CVD combined with the new solid long axle cup POM (#68770) and the universal axle pin cover (#68759) , have a very smooth movement and chattering non-existen.
AGNO is offline
Old 10-27-2011, 04:06 AM
  #3809
tak4's Avatar
Hey guys, Quick question.
Does the TCX and Cyclone share shock springs? And what is everyone using atm? Amain doesn't list any springs under the TCX page.
Thanks in advance. Much appreciated.
tak4 is offline
Old 10-27-2011, 04:12 AM
  #3810
Trader Rating: 20 (100%+)
yup. Pro4 springs. I think amain has the whole set for 30bux
goots is offline
