Like Tree2991Likes
1/12 forum
Old 10-13-2011 | 07:12 PM
  #36736
Originally Posted by YR4Dude
Lots of info in how to calculate rollout but how is the rollout determined. In other words how do you know that your track requires a specific rollout for the intended motor? Is there a method to figure this or is ths just an empirical number?
In all my years of RC racing, gearing has always been "socially engineered" at the track. However, it would be nice to know how to determine it on my own.
+1
82 spur and 60 pinion gives a range from 94-114 with tires from 41-50 which is pretty close to where we need to be. Might start with that as it gives me some room to play with tire diameter.
Thanks ericf
EDIT: Just searched for spurs gonna need to be 81 or 83 cant seem to find an 82. Recommendations on spur brands. I can get serpent ( obvious choice being its going on a s120lt) or associated or xray and kimborough. I read somewhere about having lots of holes for the balls...???
I think i'll lash out and go the sxx, save me having to much around and charge the booster as well.
Deepsouth is offline
Old 10-13-2011 | 07:21 PM
  #36737
The more diff balls you can use the less you have to tighten the diff to get the same action. This results in a smoother diff that lasts longer. CRC has a new spur gear that uses a smaller diff ball to get more in the same area and it works quite well. You will have to add spacers to that side of the axle though to keep the back end centered properly. Xenon makes a spur gear now that has as many diff balls but still uses the standard 1/8th diff balls. I've tried the CRC ones and like them a lot but picked up some of the Xenon ones at the IIC to give a try as well.
InspGadgt is offline
Old 10-13-2011 | 07:25 PM
  #36738
RedBullFiXX's Avatar
Originally Posted by Deepsouth
+1
Thanks ericf
If it's LRP for boosted, make sure you go with the Stock Spec, it's the only one that has enough boost for stock spec motors, not the TC, not the comp.
And I'm not sure you can fit spurs in the 80's with pinions in the 50-60's
That's why we have to run the smaller spurs when running higher roll.
RedBullFiXX is offline
Old 10-13-2011 | 07:28 PM
  #36739
I saw the xenon ones too will have a look.
Apparently the kit comes with 8 balls so the muchmore xray ones are out as they only have 6 holes it seems.
Yeah redbull WAAAAYY down south, I work only an hour from the most southern point in tasmania so the name is fitting
Thanks heaps for the advice, i've learnt more in the past 1hr then i've done the past few weeks, it all makes much more sense, now if I can just work out the rule to get an idea of rollout based on a specific track type. Maybe for every 10 meters/30 feet of straight = 30mm of rollout? or 1ft = 1mm of rollout per straight??
Old 10-13-2011 | 07:33 PM
  #36740
+1
Thanks ericf
The Xenon gears are the best I've seen to date.
When you figure out the rollout formula for all tracks, please post it here
Old 10-13-2011 | 07:41 PM
  #36741
Haha go figure, i'll go back to the 72 spur with a 58-60 pinion then. It will be a good start and I can see if i'm winding out and go from there.
Old 10-13-2011 | 09:51 PM
  #36742
EricF's Avatar
Note: I did say at my track...
Also, pinion grears are an investment. buy them all from 35-60 and you'll eventually find the right gear for where your racing. multiple sizes of spur are good to have around as well. PRS make a 82, Kimbrough spur gears go from a 76 and up by 4 teeth at a time.
E
EricF is offline
Old 10-13-2011 | 10:55 PM
  #36743
Is it better to run a novak smart boost or a receiver pack? If a receiver pack what brand and part number. i run a tekin rs if that helps or is there a better speed controll to run in 1/12 scale ?
guppy is offline
Old 10-13-2011 | 11:29 PM
  #36744
Hey mate, apparently running a rx pack means steadier and more reliable power to the rx throughout the race.
I have been tossing up and it seems that either you run no pack with an sxx or run a pack with the RS. Redbull above if you read the thread noted that the rs with pack is much faster with boost.
I'm going to go with the sxx no rx pack just to save the hassle of charging the rx pack.
TQ cells are meant to have the best rx packs out there for 1s http://www.tqcells.com/
Old 10-14-2011 | 12:38 AM
  #36745
dontfeelcold's Avatar
I bought a spare complete diff (individual parts) for my Associatted 12r5.1 and it needs to be done up noticeably tighter to stop the diff from slipping compared to the one that came in the kit. Both diffs are built identically and I swapped a bunch of bits around and it turns out its the main axle that is causing the issue.
Is this common?
Will the Xray full Aluminium rear axle fit? Maybe with all of the Xray parts?
http://www.teamxray.com/teamxray/pro...20Axle%20Shaft
dontfeelcold is offline
Old 10-14-2011 | 12:50 AM
  #36746
Hugh Jazz's Avatar
Is this common?
Think you will find the Xray is metric and the Associated is Imperial.
I can lend you another rear axle if you need it this weekend. I only require you to pull over and let me pass in the races lol
Hugh Jazz is offline
Old 10-14-2011 | 01:59 AM
  #36747
Infinite 12th's Avatar
Can someone explain this rollout please
Infinite 12th is offline
Old 10-14-2011 | 02:48 AM
  #36748
As i understand it rollout is how far the car travels with one revolution of the motor.
This is important as it helps to keep the motor in its workable and useable range. This keeps temperatures down prolongs the life of the motor and should keep the power drain on the batteries uniform and not like a thirsty camel.
It also helps with getting the right amount of drive for the track you are at. No point having a zippy point to point car when you have long straights and sweeping turns and vice versa.
To calculate rollout you need to know the tire diameter, pinion gear size and spur gear size plus something else that I cant remember.
check out this site for some more explaining.
http://www.carsrcracing.co.uk/?page_id=33
Old 10-14-2011 | 02:51 AM
  #36749
So it's basically how you gear something?
Old 10-14-2011 | 03:06 AM
  #36750
Hugh Jazz's Avatar
Yes. But because we are using foam tyres that wear and change size. We have to change pinions as the tyres wear to keep the same rollout or gearing.
