Lipo Connectors
Old 10-10-2011 | 09:55 AM
Brit_racer's Avatar
Questions?? Lipo Connectors
So i have my LiPos coming and i have the kind that just have three holes in them. 2s with the middle hole for balancing reasons i am guessing.
Back when i raced in the uk we used to use something called Corally connectors that look very similar to these connectors. I think sometimes people call them Orion connectors here.
I found you can order them on Hobby king etc...
Now from what i read they are 4mm? is that right?
How big is the little one in the middle?
When you guys use this connector do you still use a deans type plug or do you go straight in from the speed control. It does not seem right having 2 connectors on the way to the speed control.
Anyone know where i can see a good picture of a pro racer set up connectors with this type of plug in?
Do you ever have trouble with them popping out after a good chassis slap after a jump?
Thanks for you help
Brit_racer is online now
Old 10-10-2011 | 11:58 AM
klaymon's Avatar
They are also called bullet connectors. The main ones are 4mm and the center is 2mm. You'll see the connectors done both ways; some direct from the ESC and some with a Deans. I'm of the Deans camp simply because I don't want anything that could possibly short out. I've never had a set come out on a wreck or anything.
klaymon is offline
Old 10-10-2011 | 04:15 PM
Brit_racer's Avatar
thanks for the advice. That makes sense to me now. I appreciate all your help
Old 10-10-2011 | 06:59 PM
ta04evah's Avatar
+1
Also use the deans between the connectors for the same reason, never had one unplug from a big accident/hit either.
Cheers
Rob.
ta04evah is offline
