Tamiya TB-Evolution III
#6436
Originally posted by DJB
hey hierog what is the part numbers of those thick tamiya gears your talking about?? My gears strip quite a bit so this might be a help to my problem
The fix for me was to buy the Jurgen pieces, but now they are so thick they don't fit. I can only use the stock one way now, even the penguin back plate makes it too thick!
Anybody find a spool that works with these new gears?
#6437
Originally posted by madjack
Pretty basic set-up:
Blue 3mm upgrade chassis kit
counter sunk upper deck w/ Square center brace
Speedtech hardened steel spool
geared 96/44,
e brush, niftech springs - 11.5+, 11.2-
Mazda 6
Front:
C, A blocks
40wt, 2 hole, Assoc. blue
3mm droop, Worlds sway bar - Yellow
4.5mm ride height
long camber links, 6mm spacers
-1' camber
Rear:
A, C blocks
30wt, 2 hole, Assoc. Silver
2.5mm droop, red sway bar
5mm ride height
med. camber link, 3mm spacers
Alloy rear hubs, outside hole
-1.5 camber
geared 96/44,
Mazda 6
Front:
C, A blocks
4.5mm ride height
-1' camber
Rear:
A, C blocks
5mm ride height
-1.5 camber
madjack- you mention 96/44- is this for a 19turn? if so what 19turn did you use?
#6438
none of the EVO4 parts may be useful ot the Evo 3,
BUTTT
im sure the new tamiya gas cars graphie gear boxs look handy !!!!
BUTTT
#6439
BUTTT
BUTTT
#6441
BUTTT
BUTTT
I know speedtech has been taking pre-orders for the kit...with a little luck we should be testing at the end of July.
#6442
It was the handout 4 mag Reedy motor geared at 5.67 (not sure that I would gear that tall for other 19t's but the Reedy seems to handle it ok)
I had a chat with Blackstock about gearing these up, he said to cut the com very small and gear up to get the speed. Whats your opinon on this
#6443
Originally posted by Mabuchi
was the com full or did you cut it down small?
(by the mains I had cut my com 5 times...guess you could say it was on the smaller size, I'll try to find the motor and give you a measurement)
#6444
I would listen to Mike on that...he has a direct line to the Race dept.
#6446
Originally posted by WC
Just buy the "415 Reversible Suspension upgrade pack".
You need the longer 'bones, new knuckles and 950 bearings.
#6448
transponder holder
hey guys for the tamiya tb evoulution three is there an option for a transponder mount?? Ive seen some little bits of carbon pointing out of other peoples cars so are these bits options or custom made. Any ideas on how to make one?? Any pictures?? drilling holes into my shell stuffs the look of the body
#6449
may be its me but the transponder mounts you speak of looks like the the carbon graphite battery tie down strap cut in half and stuck to the top of the servo
#6450
Re: transponder holder
