Like Tree495Likes
JConcepts Thread
Old 10-02-2011 | 06:59 PM
  #4321
I agree J Con has the best CS I have dealt with. Even operator errors are treated with the same respect.
kstoracing1 is offline
Old 10-02-2011 | 08:20 PM
  #4322
jsinclair's Avatar
My outdoor short course racing season is over today. My only tires on the front for the season were dd's, and for the rears I'd switch between dd's and calibers. I like the dd's, but more than half the lugs are ripped clean off, and my calibers look brand new. Both of the sets have seen the same amount of use. Should I buy another set of dd's and hope they hold up? Or try something new?
Thanks;
Josh
jsinclair is offline
Old 10-02-2011 | 08:25 PM
  #4323
racer1812's Avatar
Super Moderator
We really need a 2.2 Stadium Truck CC foam, those produced by another company leave a lot to be desired..
racer1812 is offline
Old 10-02-2011 | 08:27 PM
  #4324
Thanks;
Josh
Lol Like The late great Dale Earnhart one said "Speed cost money son, How fast you wana go"
Eventually tires wear out...
Jeremy Otis is offline
Old 10-02-2011 | 08:41 PM
  #4325
jsinclair's Avatar
I understand tires wear out, they didn't wear out the lugs broke off the casing. The pins are still nearly full length. Sorry I can't while my ass with hundred dollar bills, so therefore I'd rather not replace tires every three hours of use.
Old 10-02-2011 | 10:01 PM
  #4326
Thanks;
Josh
Honestly, if you do not want to spend the money, then learn to drive better with the calibers. If they do not get enough grip, then make SMALL changes to the car, and adjust your driving style a bit. If you want a tire with comparable features as the DD's, try the Subcultures. Although a little weak on the endurance side internally for mod SCT, they have a 3 staged pattern which is helpful to lower cost because you will replace them less. I also learned that the further down the tread was worn, the better traction I had(slippery, smooth track). It also helps if you run stock classes, because there is a lot less tire spin.
Damon_English is offline
Old 10-04-2011 | 06:24 AM
  #4327
TJMac's Avatar
Originally Posted by PW
The gears are machined instead of molded; this gives you a much truer running gear for better gear mesh. The slipper-pad is also captured in a deeper pocket that better holds the pads. The gear also has markings to tell you what tooth count it is without removing.
They are in transit via slow boat; so a couple more weeks.
Sounds good to me.
I also wanted to comment on your tires. I've been mounting a bunch of new rubber as of late and I've noticed that your tires mount and balance so much easier it's rediculous. Thank you!
TJMac is offline
Old 10-04-2011 | 09:30 AM
  #4328
F18engineguy's Avatar
Default New Hex wheels for 1/10 scale
Just wanted to see if there any updates as to when these will be available? Also, are they always available on the JC site before anywhere else? thanks!
F18engineguy is offline
Old 10-04-2011 | 09:53 AM
  #4329
TJMac's Avatar
Rear hexes for the B4.1/B44.1 would be awesome. I had no idea these were in the works....sweet.
TJMac is offline
Old 10-04-2011 | 10:12 AM
  #4330
PW's Avatar
PW
We don't have a date yet; you will see an official press release when it's getting close .
The JC site normally has them a few days early.
PW is offline
Old 10-04-2011 | 08:11 PM
  #4331
Are the 3344B Hazzard wheels avaliable somewhere? I didn't see them on the site. What about the white version?
sstoffer is offline
Old 10-04-2011 | 08:48 PM
  #4332
Losiho's Avatar
Thank you JC
I have both AE and K cars. I would love to be able to run identical rims on both types of cars and keep my spares inventory lower
Losiho is offline
Old 10-05-2011 | 05:59 AM
  #4333
J_P's Avatar
J_P
The 3344B's are in stock now, you should be good to go. We are looking into white, no date at this time.
J_P is offline
Old 10-05-2011 | 08:26 AM
  #4334
ShortCourseOnly's Avatar
What size wrench is needed for the 8/32 and 4mm SCT wheel nuts? I plan to get a set for both my SC10 and SC10 4x4.
ShortCourseOnly is offline
Old 10-05-2011 | 09:35 AM
  #4335
PW's Avatar
PW
8/32 = 11/32 Nut driver (green AE)
4mm = 7mm Nut driver (silver AE)
PW is offline
