B44.1 Thread
#676
Other than a Tekin,
It's a toss up and many have reasons why one is better than another.
The new Orion ESC. Looks real good
Tekin. Rs will work, but a Pro would be better. Still 300 bones
Mamba Max Pro. Not the smoothest system on the market, but will get the job done. I ran a 5700 for a while.
Viper. They are pretty new to the market, but looks pretty decent.
LRP. many like them and I have a old Sphere in my 2wd.
You could also try some of the hobby wing stuff and Speed passion. I think both of those are fairly cheap to come by.
If all alse fails, hit up the flea bay. That's how I got my Tekin setup cheap.
#678
When I built this thing I thought it was odd that the spur gear wasn't supported on the slipper shaft by a bearing. Losi's used a bearing on the spur forever and it really helps keep the spur concentric to the slipper shaft. Has anyone tried machining the spur gear to get a bearing to fit? I don't like the fact I can press on the spur and get it to move perpendicular to the shaft.
#679
#682
Most of the current gen LiPo Saddle packs in a hard case seem to be the same size so you shouldn't run into too many issues.
The hieght of the saddle packe could be one issue if you're trying to run like a 6000 MaH pack.
#684
#685
#686
1Likes
