Hot Bodies TCX
Old 08-18-2011, 12:27 PM
  #3451
k_bojar's Avatar
Trader Rating: 30 (100%+)
if anyone is looking for a set (2) of the exotek 46mm steel shafts, shoot me a PM...I was a dope and ordered 4 not thinking that they were for the front only
k_bojar is offline
Old 08-18-2011, 02:43 PM
  #3452
Cool New parts
It's great to see new parts , but when and where do we get them
Peter Reardon is offline
Old 08-18-2011, 03:48 PM
  #3453
spring71's Avatar
Smile
Spec-R TCX Graphite Upper Deck (2.0mm) VERSION 2 is arrived at TQ.
http://www.tqrcracing.com/shop/produ....asp?p_id=2151
Click here to visit TCX Parts Store.
FYI, Thanks.
spring71 is offline
Old 08-18-2011, 04:27 PM
  #3454
san.'s Avatar
Trader Rating: 61 (100%+)
Originally Posted by k_bojar
ditto! I've changed a few things (like the lowered shock towers), but i'd rather be able to buy them if/when I need them, then to get them in a kit and that becomes the 'standard' stock setup
+1
san. is offline
Old 08-18-2011, 04:59 PM
  #3455
Trader Rating: 86 (100%+)
FYI, Thanks.
whats benefit of using new spec r top deck?
littlealex is offline
Old 08-18-2011, 07:21 PM
  #3456
www.spec-r.com says: "Newly designed Graphite Upper Deck for HotBodies TCX. Increases steering response resulting in improved cornering performance."
-Mike
grippgoat is offline
Old 08-18-2011, 10:22 PM
  #3457
-Mike
did anyone tried it? is it really "increases steering response" and "improved conering performance"?
my question is, is it worth getting it for our tcx
Old 08-19-2011, 12:13 AM
  #3458
EJ20's Avatar
Default Narrow Chassis (#68760)
Originally Posted by Matt W
Hey, couple of questions about the new chassis.......
Do we know how the new chassis will affect the handling of the car?
Has it got more flex than the stock chassis?
Is it better suited to high grip or low grip situations?
Any input would be appreciated!
Originally Posted by Hi-LowBlow
We run on multiple different track conditions for testing. The kit stock chassis works really well on low bite of-course with the flex and also on the high bite as now we want almost the same amount (may be even more) of flex for the high bite condition. The chassis works really well on both conditions.
On the other hand, the new option narrower chassis (#68760) has a bit different flex characteristic. We found that the new chassis gives the car more aggressive drive feel compare to the stock one. You might feel kind of hard to drive but for some condition it works really well. I think it's nice to have both the stock one and the optional one as setup parts.
Thanks,
EJ20 is offline
Old 08-19-2011, 12:51 AM
  #3459
AGNO's Avatar
I tried it, it is true, it increases the steering, because the upper deck Spec-r is more rigid than the standard, but being more rigid, the reactions of car are less predictable in the event of low grip, it works well under conditions of medium / high grip.
AGNO is offline
Old 08-19-2011, 05:34 AM
  #3460
hacker's Avatar
Trader Rating: 141 (100%+)
Default spares
what's the situ with the spares of late?
I was going to buy one when they were first released, but the lack of parts availability put me off.
Also, what arms are people using, the hpi pro4 ones or standard arms?
hacker is offline
Old 08-19-2011, 05:38 AM
  #3461
Mike Haynes's Avatar
I have been using tamiya arms, much stronger and easy to find.
Mike Haynes is offline
Old 08-19-2011, 06:54 AM
  #3462
louielou's Avatar
Trader Rating: 16 (100%+)
Default part #
What is the part # of the tamiya arms?
louielou is offline
Old 08-19-2011, 07:30 AM
  #3463
gashuffer's Avatar
Trader Rating: 48 (100%+)
They are the reversable arms. No part number. You can Google them.
gashuffer is offline
Old 08-19-2011, 11:54 AM
  #3464
Barry_Hughes's Avatar
Haven't found much of a problem getting the HB arms - funnily enough since I now have 5 sets as spare I haven't broken an arm
Barry_Hughes is offline
Old 08-19-2011, 11:58 AM
  #3465
k_bojar's Avatar
ditto here - except I think i have 8 or 9 sets of arms
k_bojar is offline
