Like Tree86Likes
Hpi Pro 4
Old 06-23-2004, 04:13 AM
  #5731
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by Loman
Does anyone know the old one-way gear can fit the new version small bevel gear?? If yes I can save the PRP back plate
The Old ONE WAY Gear "will" work with the new Bevel gear.... No problem
-Dave
JDM_DOHC_SiR is offline
Old 06-23-2004, 05:09 AM
  #5732
VenomWorldOrder's Avatar
Originally posted by rc_square24
just a question...in situations where i need a stiifer suspension but have no harder springs.....will cranking the preload and leaving everthing else the same give abit of a stiifer sus. feeling? like for emergencies?
move the shocks up as far as possible, if this isn't possible get harder tyres....but the best thing is to invest in a full set of associated springs
if you do the shock collar thing you will have no droop, effectively making that end "stiffer" ie no weight shift....but in a bad way.
VenomWorldOrder is offline
Old 06-23-2004, 05:10 AM
  #5733
Hi (first sorry my english)
Where can I buy the white springs, which Atsushi is driving the most time?
greets
freez
Freez is offline
Old 06-23-2004, 06:07 AM
  #5734
greets
freez
The Springs that he uses are made by HYBRID(AKA Mirage) but they are the same spring rates as A.E.`s
-Dave
Old 06-23-2004, 07:26 AM
  #5735
what is A.E.`s? Where i can find it in the internet? Do you have a page?
thanks
Freez is offline
Old 06-23-2004, 07:36 AM
  #5736
Frank McKinney's Avatar
AE is Associated Electronics, or just Associated. If you go here you can get the HPI spring chart with all the spring rates in pounds per inch and also in grams force per millimeter. This will help you see where the Trinity and Associated springs fall in comparison to the HPI line.
The last I heard, Hara just paints his springs white so no one can see what he's running, and that's just what he likes. I could be wrong though.
Frank McKinney is offline
Old 06-23-2004, 10:34 AM
  #5737
RCBuddha's Avatar
Trader Rating: 40 (100%+)
No, cranking down on the preload collars does nothing but raise your rideheight. try changing your shock oil weight or the piston hole size (to a smaller diameter). Or, just go and buy an AE Spring kit...
Buddha
RCBuddha is offline
Old 06-23-2004, 06:43 PM
  #5738
onnetz's Avatar
is that still true with progressive springs?
onnetz is offline
Old 06-23-2004, 06:50 PM
  #5739
rc_square24's Avatar
what are the mods required to fit yokomo outdrives into the pro 4....i have a pair of them...so far i can see that i need to enlarge the dirveshaft slots and need yokomo rings.
another question are yokomo rings the same as asociated ones? like will the round associated rings fit in the flat spotted yokomo drives?
thanks
rc_square24 is offline
Old 06-23-2004, 08:20 PM
  #5740
Pit-racer's Avatar
Just got my pro4, and what are the must haves? Or do I have it all RCBuddha?
Pit-racer is offline
Old 06-24-2004, 12:53 AM
  #5741
SpeedTech's Avatar
Hi Guys,
I know some of you have been asking about suspension parts (mainly the suspension arms) we got a limited number of them in stock along with some hub carriers and steering blocks.
Steve Wang
SpeedTech is offline
Old 06-24-2004, 04:52 AM
  #5742
raving-monkey's Avatar
i might have an AE spring kit for sale soon if anyone is interested
raving-monkey is offline
Old 06-24-2004, 08:06 AM
  #5743
tsolokoy's Avatar
Post White Springs
greets
freez
Freeze,
I can't tell you where to buy those springs, but i can tell you where to buy the white paint he's using on his springs...
tsolokoy is offline
Old 06-24-2004, 08:17 AM
  #5744
Super Steve's Avatar
I broke my other aluminum steering knuckle practicing....
NEVER BUY ALUMINUM KNUCKLE for the PRO 4 from RCSquare!
Super Steve is offline
Old 06-24-2004, 09:08 AM
  #5745
Skill's Avatar
I've ordered some alloy steering knuckles and C-hubs from AsiaTees purely for durability purposes. They are Jet ones so hopefully they will hold up well as they look much stronger than the Square ones.
I'll let everyone know if I have any problems.
Skill is offline
