Endurance Motor
Old 06-17-2004, 09:44 PM
  #31
JimmyMac's Avatar
How bout and asian stock arm (23t) in a mod can with low timing? I've been thinking on building a 1 hour enduro motor for our track if we ever did an enduro race we talk about. I've also thought about a nice efficient 12x2 wit moddest timing.
JimmyMac is offline
Old 06-17-2004, 09:50 PM
  #32
Entropy's Avatar
23T stock arm sounds safer IMO... The main stuff I'm worried about is temp, comm and brush wear... I do not want to have to change a motor during the race.
Reasonable speed is also a plus.
Entropy is offline
Old 06-17-2004, 10:54 PM
  #33
Wild Cherry's Avatar
Reedy quad kr can
Reedy endbell > modified endbell for a laydown brush on positive,
a *standup* brush on negitive
brush type > use orion enduro
p2k arm
timing 5 degree
standard brush springs
gear for runtime ( a tooth or two smaller than normal )
Will last 9hr <>10hr
Wild Cherry is offline
Old 06-17-2004, 11:30 PM
  #34
Entropy's Avatar
Anyone got experience with V2 endbells on other motors?
Entropy is offline
Old 06-17-2004, 11:49 PM
  #35
jeffreylin's Avatar
I think the winning car for the Tamiya spring enduro (4 hours) uses a brushless set up.
jeffreylin is offline
Old 06-18-2004, 12:17 AM
  #36
tornado
Guest
Posts: n/a
Hey Entropy ...... do they restrict brushless motor for this enduro ?
If not....use it....your problem solved...else.... you could try wild cherry's idea. I've yet to try a motor with V2 endbell......
Old 06-18-2004, 12:22 AM
  #37
Entropy's Avatar
I don't think so, but the weather is warm where I live (can get 30+ degrees celcius) in the day and I've personally seen some thermal shutdown cases in open races here. Even with fans on the ESC and BL.
I do have a Novak BL at my disposal should it be needed...
Entropy is offline
Old 06-18-2004, 12:26 AM
  #38
jeffreylin's Avatar
There certainly was that at the Tamiya enduro I heard. I don't know enough about brushless but I imagine that they should run cooler without the brush and give you longer run time.
Old 06-18-2004, 12:30 AM
  #39
tornado
Guest
Posts: n/a
Hmmm..... I'm from Kuala Lumpur.....we experience the same weather .....yeah ...Novak has the thermal shutdown problem... well I guess building a stock motor (23T) with a modified can and endbell is ur answer. I've read 'bout the V2 endbells improving motors performance and durability....mine is on the way ..... so unable to help you on this for now. Wild Cherry's idea looks promising.
Old 06-18-2004, 12:35 AM
  #40
Entropy's Avatar
Yeah, will prob follow Wild Cherry's idea but prob substitute a V2 endbell and orion enduros.
thanks
I'm still open to other ideas on how to keep motors cool and running in top condition during the short pitstops.
Entropy is offline
Old 06-18-2004, 12:39 AM
  #41
tornado
Guest
Posts: n/a
Try putting a little fan blasting at the endbell. That helps a lot.
  #42
rcsabah's Avatar
heatsink, airscope, fan
rcsabah is offline
Old 06-18-2004, 12:43 AM
  #43
Entropy's Avatar
Idea
Wonder if anyone has tried ducting on RC cars before... kinda like the side intakes of some sports cars... since this ain't a race of speed.. aerodynamics won't matter as much...
Entropy is offline
Old 06-18-2004, 02:52 AM
  #44
tornado
Guest
Posts: n/a
wot car you're driving ?
Old 06-18-2004, 07:35 AM
  #45
newracer's Avatar
I ran a Novak brushless in a 45 minute enduro with great sucess (2nd place). It was in a pan car but there were others with TCs that worked good too. We did have a small CPU fan in front of the esc to help keep the temp down.
newracer is offline
