RC10B4.1 FT/WC
Old 06-21-2011 | 10:34 AM
  #3376
Instead of all this typing about the springs rubbing, why don't you guys file the ends of the springs flat to at least prevent some of the rubbing. Pretty sure you'd all be done by now if you look at how much time you've spent arguing the fact that they rub the shock body... Just sayin'
adam lancia is offline
Old 06-21-2011 | 10:43 AM
  #3377
Armaan's Avatar
I can't bring my cars and tools to work. Moreover, I don't want to mess around and file springs...rather just spend $15-20 and pick up the superior and properly engineered springs from Kyosho. AE's top two drivers are using them, and it seems the consensus agrees.
Don't get me wrong...if AE comes out with the proper springs, I'll be thrilled to buy 'em.
Armaan is offline
Old 06-21-2011 | 10:58 AM
  #3378
ovalracer1m's Avatar
suggest for the Ft spring
orange,yellow , dr yellow
rear spring
yellow , silver , blue cobalt
start with yellow ft & yellow rear
If you are finding track conditions with higher traction ?
try the rear silver or even the blue cobalt if traction is very high
been using the dk yellow ft & yellow rears most of the time ...
thanks for the info. Just one question, if a guy normally runs a brown/green combo on a low/med grip track with AE springs wouldnt a good starting point be Kyosho orange fronts and black rears? Even more so since they have a more progressive rate... The above recommendation seems a bit stiff in the rear to me but I could see on a on a higher traction track? Not disagreeing with the above post just more of a question of what guys are finding works. thanks
ovalracer1m is offline
Old 06-21-2011 | 11:08 AM
  #3379
I am sure it has been gone over, but I want to know exactly what does what, as to understand why the changes change the car. Anyways.. From kit setup, to get rid of the push that it has, would I need to move to the inner hole on the front shock tower, and lengthen the tie-rods? What would each do?
dirt_oval is offline
Old 06-21-2011 | 11:13 AM
  #3380
http://www.rctech.net/forum/nitro-of...ides-hudy.html
should walk you through every component of the car to change setup.
Old 06-21-2011 | 11:27 AM
  #3381
Asharus's Avatar
Excellent link.
Asharus is offline
Old 06-21-2011 | 01:26 PM
  #3382
Cpt.America's Avatar
Anybody here run a 7.5? I run a 7.5 LRP x12 and was curious as to how you are gearing. I run on a decent sized indoor high grip clay track.
Cpt.America is offline
Old 06-21-2011 | 02:04 PM
  #3383
idrummerboy13's Avatar
my friend is letting me try his losi xxx cr shocks on my b4.1 ill let you guys know how it comes out=] they seem alot nicer but ill make a post about how they work later, off to run!!!
idrummerboy13 is offline
Old 06-21-2011 | 02:19 PM
  #3384
Armaan's Avatar
Feelin a little nostalgic...
Team Car
Championship Edition
Worlds Car
First RC10T
Pavidis' T3
Armaan is offline
Old 06-21-2011 | 02:56 PM
  #3385
ffiB's Avatar
Team Car
Worlds Car
First RC10T
Pavidis' T3
Oh yea!
ffiB is offline
Old 06-21-2011 | 02:58 PM
  #3386
ffiB's Avatar
Heck, I still have an original pre-stealth 6 gear tranny gold tub. And a RC10T!
ffiB is offline
Old 06-21-2011 | 03:25 PM
  #3387
CR shocks aren't bad, but they aren't as good as V2s with K springs.
Old 06-21-2011 | 04:17 PM
  #3388
bds81175's Avatar
Moderator
Did you ever pin your dif? Did you do the outdrive bearing mod? I remember "tweaking" the gear plate in order to get the same level of freedom for both sides of the gear box. I also recall when the original RC10 came out and it glided over the track (compared to my Hornet...yes I raced a Hornet).
bds81175 is offline
Old 06-21-2011 | 04:45 PM
  #3389
ffiB's Avatar
I never ran the pre-stealth car. I started with the CE unless you count that Panda truck thing.
Attached Thumbnails RC10B4.1 FT/WC-img_2801.jpg
ffiB is offline
Old 06-21-2011 | 04:50 PM
  #3390
Originally Posted by baneonrt
The Savox 1257 is probably the best choice followed closely by the 1258. No need for the extra torque of the 1258 in a buggy though. Savox direct is selling them for $47 if you have an old servo to send in. They charge the discount during checkout and don't have any identifying information on the return so I'm not sure how they're tracking this. I'm assuming it's just a marketing thing and they really don't care if they get a servo back.
Ordered two of them a week ago or so and had them in a couple of days. Was $100 shipped for both.
Steve
I'm trying to get my Savox 1258TG mounted in my B4.1FT.
None of the horns fit the servo. Did you get it to work? If so, which horn and which spacers did you use?
None of the horns with the kit seem to even begin to go onto the servo.
HeavyDuty is offline
