Tamiya mini cooper >
Tamiya mini cooper
Like Tree295Likes
Tamiya mini cooper
Old 06-08-2011 | 04:22 AM
  #15091
caltek1's Avatar
The MO5 S Spec is due for release in mid July in Japan.
The new optional parts are due out after the kit has been released for a while, according to Champ, so that they sell the kits which are supposively limited.
Hopefully will have mine not long after release.
ska_seattle,
Just make sure you fit a Lipo cutoff to your mini if you are using old type ESC.
Later,
Calvin.
caltek1 is offline
Old 06-08-2011 | 10:07 AM
  #15092
Shangrila's Avatar
Thanks Calvin
On rcmini.net there has not been an update mentioning this, nor is it discussed much on here,
is there alot of benefit being found with upright shocks (using the extended shock tower) on asphalt?
I get the feeling it would work better than the std inclined layout.
Shangrila is offline
Old 06-08-2011 | 01:51 PM
  #15093
caltek1's Avatar
Shangrila,
On the MO5 with the shocks in the standard position they are more progressive in how they work. I have added the Tamiya alloy shock tower and have found the car handles better on most surfaces.
I use the second outer hole on the tower and find the car more predictable to drive. On carpet I have found this also stops the front from biting in and slowing the car when cornering.
Just my thoughts.
Calvin.
caltek1 is offline
Old 06-08-2011 | 02:30 PM
  #15094
tony gray's Avatar
Standard mounts - my car was soft and mushy and understeered
Optional mounts - more precise, craploads more steering, miles better.
Laid over shocks are always a compromise, the shock tends to pivot around the upper point instead of compressing.
tony gray is offline
Old 06-09-2011 | 06:08 PM
  #15095
What LIPO batteries fit in the M03 chassis ??
or , what are the dimensions of a battery that fits the M03 ?
Mr.Pink is offline
Old 06-09-2011 | 08:07 PM
  #15096
Timbulb's Avatar
The batteries you sell fit in the M03.
edit: oops, you're not Mister Pink from Calgary.
Timbulb is offline
Old 06-10-2011 | 12:12 AM
  #15097
Dan's Avatar
Dan
Had a nasty hit with my M05 at the track today and bent a steering knuckle. Any recommended upgrades? Or just one of those things where it was a big hit and I should just replace with stock?
Dan is offline
Old 06-10-2011 | 12:59 AM
  #15098
monkeyracing's Avatar
If you're going to replace the steering knuckles (aluminum ones) be sure to stick with the Tamiya parts. The other brands may be cheaper, but there's a reason for it.
Jim
monkeyracing is offline
Old 06-10-2011 | 01:39 AM
  #15099
Dan's Avatar
Dan
Actually bent the plastic stock ones. The Tamiya units are pricey. Guess I'm sticking to stock.
Dan is offline
Old 06-10-2011 | 01:53 AM
  #15100
cannon's Avatar
Jim
Jim
You are actually a long way off now days. Both 3 Racing and Yeah racing have changed a lot in the past few years. Their knuckles are very high quality now and far cheaper than the Tamiya parts
cannon is offline
Old 06-10-2011 | 04:44 AM
  #15101
One reason for going Al knuckles is stripping kingpin holes. Hit the plastic knuckles enough and the holes stretch, the kingpins loosen and fall out.
Interesting that the "rubber" lower arms didn't give and you got a bent knuckle.
Were you at FPR, All Speed or Norcal?
Sydewynder is offline
Old 06-10-2011 | 09:15 AM
  #15102
Dan's Avatar
Dan
Hmm...could always use more blue eye candy... I was at Norcal yesterday and giving a try at the Reedy race layout. I was just running the silver can but pretty much had the throttle trigger pegged and with foam tires, it was stupid fun not letting off.
You going to be at All Speed this weekend or next? I may try to come out since I finally have a mini vacation.
Dan is offline
Old 06-10-2011 | 10:11 AM
  #15103
Foams are fun.
You have PM
Old 06-10-2011 | 11:53 AM
  #15104
superspeed's Avatar
Default foam tires
my opinion on using foam tires is it's less interesting/challenging to drive the vehicle.
m05 s-spec will be more expensive than other m chassis including the pro kits.
superspeed is offline
Old 06-10-2011 | 12:40 PM
  #15105
Originally Posted by cannon
Jim
I guess I'd have to say "once bitten, twice shy" to that, Tim. It's more like getting bitten a bunch of times, really. I haven't run any of the aftermarket knuckles in a few years, so perhaps the quality has improved, but I did have a bad run with them for a few years and watched others struggle as well.
I'll run aftermarket parts almost anywhere else on my car; uprights, dampers, steering components, axles, etc. have never presented me with a problem.
Still won't use aftermarket knuckles.
Jim
