Hyperion EOS 0615i Duo3 >
Old 06-01-2011 | 11:23 AM
Default Hyperion EOS 0615i Duo3
I am confused, is this normal of a power supply to drop in voltage during a charge and then ramp up, and the charger go down to charging at 0 amps then go back to where it was?
Check this video to see what I mean. http://s737.photobucket.com/albums/x...-15-30_242.mp4
cmnyj28rctech is offline
Old 06-01-2011 | 04:54 PM
I can’t get the video to run on this old clunker I’m using, but, the big Hyps pause occasionally to get a better read on the lipo voltage. During that pause in the charge current the voltage will drop some.
Your description seems like normal operation.
Dave H is offline
Old 06-01-2011 | 07:13 PM
Yes, that's normal. The charger constantly monitors the progress of the charge and varies the voltage and/or amperage accordingly.
Btw, the LCD read out on your power supply is amperage:
Technical Data:
• Input voltage range: 190~240v AC
• Output voltage: 13.8v DC regulated
• Current rating: 0~20 Amps
• Output connections: Twin 4mm Banana/Clamp type
• LCD Amperage readout
ganymede is offline
Old 06-01-2011 | 09:55 PM
racer1812's Avatar
Super Moderator
Agree, this is normal for Hyperion
racer1812 is offline
Old 06-02-2011 | 04:40 AM
Thanks guys, i feel much better, I was a little concerned but it was still charging, now I'm happy, thanks for the help.
