The New Werks B5 .21 Racing Engine >
Like Tree63Likes
Old 05-19-2011 | 03:27 PM
  #7066
alexrckid's Avatar
gotta do some serious twistin and pullin......
alexrckid is offline
Old 05-19-2011 | 03:28 PM
  #7067
alexrckid's Avatar
oh.....and remove the pinch bolt before twistin and pullin
  #7068
Muggydude's Avatar
Originally Posted by Nytrocrzy
I can't get the carb out of the crankcase. Any ideas?
Make sure you take the carb screw all the way out.
Muggydude is offline
Old 05-19-2011 | 03:45 PM
  #7069
Pinch Bolt is all the way out. It twist easy but I cant pull it out. I am using channel locks with a rag between the jaws to protect the carb body
Nytrocrzy is offline
Old 05-19-2011 | 03:47 PM
  #7070
Might have to put I in a vise. The case looks strong enough
Old 05-19-2011 | 03:51 PM
  #7071
brandundecided's Avatar
The bolt is out but are the 2 small pieces that the screw goes through out? If not these will need to be removed another issue you might have is if the pinch bolt was over tightened and causing the insulator to flare out where it was squeezed.
brandundecided is offline
Old 05-19-2011 | 11:17 PM
  #7072
Razathorn's Avatar
You can also heat the neck with a heat gun and that will help in two ways -- it will expand the neck a bit and it also makes the plastic material that the carb neck insert is made out of a bit more flexible. I've found that trick really helps. You don't even have to get it super hot to make it slide out easily.
Wayne
Razathorn is offline
Old 05-20-2011 | 04:26 AM
  #7073
I never take the pinch bolt out on the rare occasions I need to remove the carb..
I loosen the bolt about 5mm then push it back in to pop out the other half of the assembly then twist it and pull it out..
I havent used channel locks on a carb before but it CANT be good.
if you having trouble maybe take it to someone at the track who has dont it before and have them give you a hand.
Mo Denton is offline
Old 05-20-2011 | 05:12 AM
  #7074
just ordered my b5, cant get werks fuel local has anyone evr ran sidewinder team strike fuel?
jenson40 is offline
Old 05-20-2011 | 05:55 AM
  #7075
yes I have before the Werks fuel.... runs good, good runtime, not as good as for the engine as the werks is but it would be my second choice.
Werks fuel is just better in everyway.. I am sure somewhere out you way is a distributer???
Old 05-20-2011 | 07:20 AM
  #7076
marshon50's Avatar
hey man,
Where's Johnson City, NY? I'm a distributor for Werks Fuel in the NY/NJ/PA area. And as always, if you guys are looking for Werks Fuel locally, ask your LHS. If you create the demand, your the customer, they'll try to meet your needs.
marshon50 is offline
Old 05-20-2011 | 03:20 PM
  #7077
im alitte over 2 hours from barnstormers
jenson40 is offline
Old 05-20-2011 | 04:02 PM
  #7078
DPowers's Avatar
Got my motor today Ron thanks.
DPowers is offline
Old 05-21-2011 | 07:36 PM
  #7079
fastestcat's Avatar
Purchased new b5 from amain already broken in.... Had several people try but we can not get it tuned.... Big problem is top end breaks up .... I'm using a reedy pipe
fastestcat is offline
Old 05-21-2011 | 08:00 PM
  #7080
What have you done with the needles?
