Airtronics M11X
#1126
#1128
To anyone wanting to use a lipo and not lose the feel and balance of the nimh packs try the thunderpower Prolite G4 1800mah lipo. Wieghs 15 grams less than the nimh pack and feels almost the same in the Radio. Ive added some foam to stop it moving around and this has added almost the missing 15 grams.
IMO IP lipos are cheap crap and I will not use inferior products in such a high end radio.
I've been using their NiMH packs for more than 7 years with not 1 single problem. I've also been using both their LiFe & LiPo packs for about 18months now, also without a single problem ever. Really sounds like "cheap crap" to me too.
#1129
#1130
Since you are not familiar with the servos and you have only used one Sanwa servo 3 years ago not sure if you are qualified to chime in on their servos. Do you even have an m11x? MT4? Know what SSR is or what it does? He is looking for a specific line of servos to be used in SSR mode with a SSR receiver.
Yes it is the low-profile im looking at ive read that only sanwa servos can be used in ssr mode with the 451R receiver i was not aware of this until after
purchase. (normally use savox no probs ever).
I run 1/10 on road and the power is fine it was the speed when used with
the 451R that i was checking on.
Im hoping to get more of an edge with the faster response time.
#1134
Hi Guys,
In the RX-451R instructions, it says "do not use a receiver battery greater then 6.0v to power this receiver"
I have used LiFe in my past KO gear. Is LiFe (6.6v) receiver batteries ok to use?
Thanks,
Thanks,
#1137
Okay i found out i need help getting it out of custom menu. Please help me find the steps. I have a manual and found it in there but it says to go to C-menu but since its in custom menu C-menu isnt there.
#1139
Hey guys, does anyone no if a 2cell lipo 2000mah Losi pack will work in a m11x, I'm not talking about if the slide works, just if the actually battery being lipo directly being plugged in will be ok, I don't mind doing a lil hacking to make this work!!
