Like Tree1Likes
JP engines
Old 03-25-2011 | 05:24 AM
  #1066
That is the standard R7 rod, everyone selling Novarossi should have it
Roelof is offline
Old 03-25-2011 | 07:37 AM
  #1067
SOLOARTIST 702's Avatar
thanks
SOLOARTIST 702 is offline
Old 03-28-2011 | 01:40 PM
  #1068
rod on the way count down to worlds
Old 03-28-2011 | 09:24 PM
  #1069
something
Old 04-01-2011 | 09:48 AM
  #1070
FASRICK's Avatar
Anyone knows where to get a piston/sleeve for a Eagle R-9 ?
THANKS
FASRICK is offline
Old 04-01-2011 | 11:19 AM
  #1071
THANKS
check with serpent usa desotoracing he should be able to help
Old 04-01-2011 | 04:13 PM
  #1072
Or get a P/S set from:
- 35-plus-21
- 359
- Gimar R08
- Flash
Roelof is offline
Old 04-03-2011 | 02:36 PM
  #1073
FASRICK's Avatar
- 35-plus-21
- 359
- Gimar R08
- Flash
Thanks Roelof
FASRICK is offline
Old 04-10-2011 | 01:06 AM
  #1074
rcmike's Avatar
Default what pipe n header for mileage more than raw power
For a mig 21 r 09 tuned ? thx
rcmike is offline
Old 04-12-2011 | 11:01 AM
  #1075
GREGORY!'s Avatar
hi guys.what's your thought about the jp 35 plus 21?
i know that it's old one but i want to know how can this compare with the new novarossi and nova based engine.
thanks in advice.
GREGORY! is offline
Old 04-12-2011 | 11:09 AM
  #1076
I have bought a JP modded REX 35-plus-21. The timings are like an Eagle so it should perform the same. It comes with a black coated crankcase (not that will give an improvement) and the DLC coated crankshaft.
Roelof is offline
Old 04-12-2011 | 11:26 AM
  #1077
GREGORY!'s Avatar
there is any diff with the newer 2010-2011 novarossi tuned 35 plus 21 engine?
GREGORY! is offline
Old 04-12-2011 | 01:20 PM
  #1078
I can not tell, I think Novarossi can not tell either..... from time to time NR is changing specs without telling.
From the 3 JP modded 35+ I have seen they all had the same crank timing. JP has determed his own specs or is changing the original with some left over cranks from his JP engine line. The main differenses I have seen were the exhaust height and from that I can see that through the years they do become higher.
Attached a smal list with timings with some 35+ engines listed
Roelof is offline
Old 04-12-2011 | 01:55 PM
  #1079
GREGORY!'s Avatar
Thank you Roelof.
i think i can't go wrong with that angine.
GREGORY! is offline
Old 04-22-2011 | 03:43 AM
  #1080
chicky03's Avatar
I got to run the new jp gimar 9.1 at the worlds and was very impressed. It had more bottom end than the 2010 version. If any one is interested in them I can point you in the right direction for availability. [email protected]
chicky03 is offline
