charging pb battery
Old 03-01-2011 | 04:05 PM
Default charging pb battery
i have a 12v 7ah lead acid battery for my starter box and a turnigh accucell 6 charger to charge it .. i charge at .7amps when it gets to 14.7v is goes down to .2amps (i think maintaining the charge) my question is will it stay like that forever of eventuall stop and say battery charged or something like that?
also there is a number displayed in the bottom corner saying 00475 (varies a little) the manual says that is is charged capacity.. what does that mean?
boomtheroom is offline
Old 03-01-2011 | 06:04 PM
the manual says it will terminate -"The audible sound indicates you at the end of process."
The number you're seeing (lwr rt corner) is the mah input to the battery. If your batt is flat going into the charge, that's not very encouraging, this should be a bigger number. I have the charger, but use a float type charger for my 12v batts.
Duster_360 is offline
Old 03-01-2011 | 06:08 PM
sorry this number is after the battery has been regharged after being on the charger ovenight
Old 03-01-2011 | 06:13 PM
Manual says it will charge to a max of 2.46v/cell - that's the 14.7v you're seeing, thats as high as voltage is supposed to get. I don't know why yours isn't terminating - do you have capacity set while charging your 12v?
On chargeing to the 14.7v, I guess you're seeing bigger mah number?
Old 03-01-2011 | 06:14 PM
yea alot bigger
Old 03-01-2011 | 06:23 PM
When you see it get to 14.7v, then its time to stop charging, its basically finished charging.
I guess the smaller charge may be some kind of trickle charge? That's really not needed for SLA batts though.
