The Speed Passion Thread >
Like Tree57Likes
Old 02-25-2011 | 08:12 AM
  #6616
Cain's Avatar
Hey guys,
I am in the hunt right now for some ESCs with boost features, etc. as well as a 1/8 electric ESC.
I have a few questions on the lastest speed passion stuff:
1. What is considered the Speed Passion equivalent of a Tekin RS Pro? (GT2.0?)
2. Same question but for a Tekin RS? (LPF was what I considered when I had one)
3. Which ESCs include the progammer card that allows you to download updates to the firmware of the ESC online?
4. What are the thoughts on the 1/8 esc as far as using a 1/8 sized motor like a Tekin or Castle?
5. What is the warranty length now for the new stuff? (30 days, 90 days, 1 year?)
6. Which ESC can be used (other than the silver arrow v2) for 1/10 4X4 SCT usage and the 550 motors?
Cain is offline
Old 02-25-2011 | 01:08 PM
  #6617
[[john]]'s Avatar
Originally Posted by defcone
What I did was tin both the wires and the tabs a little bit, then put the remaining required amount of solder on the tip. Then hold the wire against the tab and let the solder on your tip touch the wire and should flow onto the tab.
This is what I have always done, but it didn't work with the SP. It seems the heat was all drawn away from the tabs through the Alloy Case, which made the solder quickly solidify.
It is done now though, so all is sweet
Just waiting on a 21.5 motor to arrive.
[[john]] is offline
Old 02-25-2011 | 04:09 PM
  #6618
irgo's Avatar
Originally Posted by Cain
Hey guys,
no not GT2.0 but GT 2.0PRO or GT 2.1PROSTOCK
Right GT 2.0LPF ,or Cirtix ESC.
All Speed Passion Product since Generation 2 Can be Updated and Programmed with a card included and LCD. for Cirtix, there is USB link.
Depend your class, but Silver Arrow is Recommended.
But Speed Passion had Slotless Motor 550 Cirtix, why would you need Tekin and Castle ?
GT 2.0 Pro.
There is also sensoreless NEW Speed Passion Skywalker PN:SW150
capability to use 6S.
irgo is offline
Old 02-25-2011 | 07:25 PM
  #6619
skypilot's Avatar
"face it, on road is dead" that is what you said.
From the Carpet Nats thread....
"Looks like 110 plus entries,,, and about 77 pit spots taken..... still plenty of guys still to sign up, looks like it will be a sell out, thanks guys.."
skypilot is offline
Old 02-25-2011 | 07:28 PM
  #6620
skypilot's Avatar
not true, to download and upgrade your esc you will need the LCD program box which IS NOT included with the esc.
skypilot is offline
Old 02-25-2011 | 07:31 PM
  #6621
skypilot's Avatar
...and i believe you had had something to say about this also... wrong again
http://www.rctech.net/forum/electric...las-vegas.html
skypilot is offline
Old 02-25-2011 | 10:21 PM
  #6622
RockyMania's Avatar
Hi there,
anyone of you know which software marc is using now in mod? perhaps the setting details as well.....cheerios!
RockyMania is offline
Old 02-26-2011 | 11:43 PM
  #6623
dag32's Avatar
I have the Speed Passion GT2.1 "EX" in my WGT car using 1 cell lipo, should my voltage protection be turned off? Every time I set it to any other voltage the ESC just beeps with a flashing green light.
dag32 is offline
Old 02-26-2011 | 11:49 PM
  #6624
Pattojnr's Avatar
yes i did that. i setup the ESC with a 2 cell and then turned the protection off.
once plugged back in to 1 cell. it stopped all the flashing and beeping.
Pattojnr is offline
Old 02-27-2011 | 12:57 AM
  #6625
Default Pro stock 2.1/13.5 pan car setup.
Hey guys. Having just changed to Speed Passion from LRP i would be keen on some setup advice for my widened 10r5 pro10 which we run again in New Zealand but with 13.5 motors. Any help would be appreciated. Cheers.
Bumpy is offline
Old 02-27-2011 | 06:23 AM
  #6626
could anyone post a picture of the citrix stock spec mounted on a touring car, and make or model is fine, i just want to see it mounted and try to do a size comparison...
honhon is offline
Old 02-27-2011 | 08:53 AM
  #6627
mr crum's Avatar
do you run 2s or 1s ?
mr crum is offline
Old 02-27-2011 | 08:54 AM
  #6628
mr crum's Avatar
hey i have one in my f1 i can show u next sunday at the track
mr crum is offline
Old 02-27-2011 | 08:55 AM
  #6629
i wont be at the track for alittle bit still...
honhon is offline
Old 02-28-2011 | 12:08 AM
  #6630
Mr Crum; We run 2s. I run Speed Power saddle packs. Should have also mentioned that the esc and motor ill be using are 2.1 prostock and V3 13.5. Cheers
Bumpy is offline
