First truggy advice? >
Old 02-25-2011 | 07:38 PM
  #16
mgtmadness2007's Avatar
I would def. get that ST-RR that was posted way before any Losi. I am a team associated fan and would get it before the RC8T RS.
mgtmadness2007 is offline
Old 02-25-2011 | 07:47 PM
  #17
tc5 man's Avatar
Tech Prophet
Originally Posted by cloud9graffix
Take a look at this..... This is kinda the deal you might be looking for. Just always make sure they have high rating, don't be afraid to ask for a phone number if you are truely interested, when dealing with something priced this high.
http://www.rctech.net/forum/r-c-item...ots-parts.html
wow now thats something i whould buy used thats in great shape !
tc5 man is offline
Old 02-26-2011 | 05:43 AM
  #18
dburt86's Avatar
like i said before, there are other truggies out there that are on the same level as the losi, but none of them come with the caliber of radio the losi does.
Believe me, i just went threw this.Spend the extra money now and save later.
dburt86 is offline
Old 02-26-2011 | 08:51 AM
  #19
Again thanks for all the helpful info. I can't see myself doing much more than club level racing, but I don't want to be limited by my equipment should I decide to go to a higher level.
Last night (before I read the replies unfortunately ) I took the leap and bought a Hot Bodies D8T.
It comes with 4 new Proline Caliber dish wheels and tires, 4 new Crime Fighter Proline tires and dish wheels, OFNA starter box with the big duel motors, original owners manual, Skyline XR pipe, humpback TX battery, Hitec HS645MG steering and throttle servos, and an Axial .28 Silver Top Motor.
All for $300.
The truggy itself looks very very clean in pictures.
It needs a radio and receiver but I plan to get a Spektrum DX3E for it. Also, I'm going to replace those servos with something more capable.
I know the Axial isn't optimal for racing, but I've been told it'll be fine for a practice engine.
What kind of deal do you guys think I got?
Redrawker is offline
Old 02-26-2011 | 10:22 AM
  #20
cloud9graffix's Avatar
the 645 will work fine for your throttle. But as for the steering you want more torque. This is what I run. works fantastic.
http://www.amainhobbies.com/product_...-Digital-Servo
cloud9graffix is offline
Old 02-26-2011 | 10:31 AM
  #21
I say just get it and run it and see how it goes for starters. Later, if you want to upgrade your steering servo, consider the Tower brand equivalent or Hobbico CS-170.. It's the same as the Hitec but cheaper...
As for the Axial, it's probably not an ideal racing engine cuz it will drink a lot and won't have the greatest top-end, but for starters it'll get the job done. Should also be good out of the corners and for run-ups to jumps with the extra torque...
Enjoy..
Herrsavage is offline
Old 02-26-2011 | 10:52 AM
  #22
I was a planning on switching to the Hobbico equivalent to that servo, and I might as well upgrade the throttle servo while I'm at it. That way I can sell the two Hs645's as a lot.
But yes, I agree I'll try to run it 'as is' for a little while just to see how much more I need.
Old 02-26-2011 | 11:05 AM
  #23
tc5 man's Avatar
Tech Prophet
All for $300.
thats, a good deal one thing though il tell you when i bought my 1.0 t used from a racer i knew it looked good on the outside but the drivetrain and the other things yikes alot of $$ for replacements .
so just double check the diff cases/diff gears/diff oil also.
as, for the engine its a .28 it will get you started but i know you will evently get a .21 inless you drive smooth on the throttle because it will cost $$ in fuel with .28.
the, servos since you got the d8t than go ahead and get the $100+ servos than dont know if there better really they have titanuim gears thats the only thing that seems diffrent to be honest.
tc5 man is offline
Old 02-26-2011 | 02:16 PM
  #24
Well I'll keep my fingers crossed about the internal components then. I'll go to my LHS sometime this week and get diff and shock fluid and do an immediate tear-down when it arrives.
Old 02-26-2011 | 02:41 PM
  #25
tc5 man's Avatar
Tech Prophet
if its from a pro racer than most likely it wont be bad still check it though i dont know the wear rate on the d8t drivetrain compared to losi.
tc5 man is offline
Old 02-26-2011 | 04:15 PM
  #26
you will like the d8t
morkendi is offline
