TC3 Forum
#8251
Need some help... I ran 19t last week & fried my diffs.
They were the plastic outdrives. I got some IRS outdrives
but I'm having a hard time securing the diff's with the plastic
housing that surounds the nut. it seems to go to far for the ends to be secure. What do you use when running modifieds?
Thanks for any help. MJ
#8252
Be careful when replacing the diff outdrives with aftermarket ones. I discovered that Associated changed the design of the diffs between the first series and the latest. I too fried the plastic diif outdrives in my factory team kit and as a quick fix, tossed in the old ones from my original racer kit. When I got around to replacing them with Hardcore Racing outdrives, I couldn't get the diffs to work. I later discovered that one of the internal bearings (racer kit) had been replaced with a narrower bushing (FT kit) and made all the difference in the world. It kind of sounds like you may have the same problem, the aftermarket parts are a different generation than the the ones that fried. If that's not the issue, email IRS and ask them for advice, could be something simple. Hope this helps, good luck.
#8254
Does anybody on this thread remember a post someone put up a link to their web sight and was a how to on milling the cassis out to move the batteries more center line it also had the ntc3 steering rack conversion on it anybody remeber whos web sight that was??
thanks
RandyB
thanks
RandyB
#8260
Originally posted by chef88
Thanks Java 1970 & JWatt.
Have one of you used the light weight outdrives part #3913?
& if so How did they work for you?
#8261
Hitec HS-5625MG $55
Speed: 0.14 sec/60 degrees at 6.0V
Torque: 130.53 oz/in at 6.0V
Futaba S3050 Servo Digital Standard High Torque BB MG $50
Speed: 0.16 sec/60 degrees at 6V
Torque: 90.2oz/in (kg/cm) at 6V
the hitec is pretty tempting...
the analog ones are cheaper.
Futaba S3305 Standard High-Torque Servo w/Metal Gears $35
0.20 sec/60 degrees at 6V
124 oz/in (8.9 kg/cm) at 6V
Hitec HS-625MG Servo Speed Metal Gear S/JR/Z $37
0.15sec/60 degrees at 6.0V
6.8kg-cm (94.43 oz/in) at 6.0V
what do you guys think? im trying to keep costs down to as low as possible without sacrificing potential. if its really worth it should i just go for the $90+ servos?
#8262
I have a digital KO servo, and believe me, a digital servo makes a noticable difference/improvement over analog servos. Not only are they extremely quick and strong, but you should never have to worry about the servo not centering or wandering. That HS-5625MG does look pretty good, not too expensive
65Likes
