Radio Control Hobbies & Raceway - Waterbury, CT.
Ya good job, right up to the part where he burnt the red plastic connector
About the B44.1...
Current B44 owners can just update their cars to the latest specs.
The differences: the cam motor mount, v2 shock bodies, thicker front shock tower, rear hubs, chassis, slipper springs, pads, and hubs, battery straps, body, and if you don't already have them the lipo tray and rear sway bar.
The transmission ratio is still 2.5, not 2.6. The 2.6 is a typo. The B44.1 still uses the same diff gears, 3914.
As for the wheelbase, it is shorter because the kit setup has the hubs in the forward position. The max wheelbase would be 280mm, the same as the B44.
The length of the B44.1 vs. the B44 is the same. The reason the measurement is 7mm off is the B44.1 was measured from the very tip of the front to the back of the wing.
The newer chassis is the same length as the older one as well as the same width. The servo has been moved more towards the center line as well as there are no more cutouts for motor and batteries.
Hope this clarifies everything.
Chris Jarosz
Team Associated Customer Support"
Chris Jarosz
I'll be down tonite for some 2wd Buggy action and perhaps SC.
I've also got a bunch of AE Vintage stuff to get rid of......
-RC10T Silver pan complete roller....my A-Main rig from this past year
-RC10 roller with Hot Trick red fiberglass chassis and red anodized wide front end
-RC10 Gold Pan roller with 4wd cable drive conversion
If anyone's interested, just shoot me a PM and I'll bring em tonite.
Derek.....you gonna be around tonite..........I'll bring that Wah Wah.
About the B44.1...
21Likes
