1/12 forum
Hello guys new here on the forums first I try to read as much as I can about the 1/12 cars but seems to be so much info that some is lost on this sea of post.
First I like to know what batts should I use I read in some places about lipos but don't find which is best 1s or 2s and if 2s what size or mah's it should be,second will be motors for the car if use 2s how many turns or KV should I use.I see some guys at a local track with stock brushed motors and speed seems fine to me what is comparable to that in brushless.
Any help here would be appreciated.
In general, a 17.5 brushless is considered "stock" in many places in the U.S. Also, 1s lipos are used at all major races for 1/12 scale. Almost any name brand lipo in the 4000-5000 mah range, and 30-40c should be quite adequate to begin.
Stick with it for awhile...there is a lot to learn but there is a lot of fun in the competition and the friends you will make.
I apologize if this has been asked already, I have tried searching, but there are a million different answers that come up.
I have a RC12R5.1 and RC12L4. The L4 body is not too bad, but the R5.1 body is trashed. Both cars could use a new body. Is there a standard body that most people run on 1/12 scale pan cars (similar to the Mazda Speed6 that many Touring cars race with)? I was thinking about the Protoform Speed 12, but I wasn't sure if this was a good choice. Unfortunately I have the first 1/12 scale cars at my track so there is nobody there to ask.
I am still pretty rough on the track, so I would like a body that can handle some abuse without splitting after the first mishap
There are a number of different bodies used. Largely it depends on personal preference of how much down force you want. But if you are looking for durable bodies look a the Parma Speed 8 or Speed 8 HD. Parma molds their bodies thicker than others so they are more durable...but heavier as well.
If you're just practicing and not going for ultra lightweight you can use Duct tape to reinforce the body around the post holes and across the front. The Protoform AMR is the current body of choice among pros, but it has a lot of steering built into it's aero, so if you have a problem with rear grip the Parma Speed 8HD is more forgiving.
Hey everyone, I just have a set-up question. I just got into 1/12 scale racing and although I have racing experience, I have no experience with setting up pan cars. I have a CRC Gen XL and I'm running on carpet so of course I'm in a high traction environment. The car handles really well but I can be faster if the diff didn't unload as easily when I exit corners. I was thinking that I probably need stiffer side springs...is this correct or is there something else that I should try first? In any other form of racing you'd have the option of tightening the diff but the manual says that in 1/12 scale racing it is critical to have the diff as loose as possible without slipping.
The softer side springs will make the care lift it's wheel less easy. The softer center spring will slow down the weight transfer and there fore lift the wheels also less easy. But softening the side springs will make a set-up changes and maybe loose some reaction. If you don't like that make the side tubes a litte stiffer.
Also try to drive les camber at the front wheels (1deg) and try putting some sticky stuff on the front susp shafts (under the front springs). This will also slow down the weight transfer. Less but not least put the battery in front (if not already there) and just try to "corner" easyer, try some steering curve (-10%).
I assume you have already widend the front end (168mm / 169mm) and glued the front tires?
Good luck!
Best Regards
Robert
Robert
This was 3.7V on both equation in the 12th. Its more to do with the corner speed in 1/12
Antoni
With harder side springs the car will "feel" easyer but tent's to lift it's rear wheels faster. Try running softer side springs and also a softer center spring.
Good luck!
Best Regards
Robert
Robert
Good luck!
Best Regards
Robert
Robert
Your "think wise" is good about the springs. In general: Softer spring, more traction, stiffer spring more reaction. Although it's a pancar with (as far as I understand from your post) a lot of grip. Some physic laws don't just work anymore (because of both!). Making the side spring softer will make the car "lean" more, instead of flippin' over or lifting it's wheels because of a too hard side spring.
Robert
2991Likes
