Like Tree2991Likes
1/12 forum
Old 10-02-2010 | 03:58 AM
  #34771
rc_square24's Avatar
I was wondering why most 1/12 scale cars I see have the solid fibreglass antenna rods with the antenna wrapped around them, instead of the flexible tubes used on TCs?
rc_square24 is offline
Old 10-02-2010 | 04:11 AM
  #34772
20 SMOKE's Avatar
its a roll over antenna
20 SMOKE is offline
Old 10-02-2010 | 04:15 AM
  #34773
What does that mean and why for 1/12 1/10 on roads only and not TCs?
Also when I cut my speed12b body, theres a piece that looks like a flap on the rear bottom of the mould, what is it for?
Thanks for answering my questions as I'm new to 1/12.
Old 10-02-2010 | 04:27 AM
  #34774
whynot's Avatar
It stops the car from sliding upside down and the fiberglass antenna can flip the car back onto its wheels.
whynot is offline
Old 10-02-2010 | 05:55 AM
  #34775
Scottrik's Avatar
AND the roll-over antenna is ONLY allowed in 1/12 per the rules (ROAR and, I believe, IFMAR), they are specifically banned in other classes. Hence no touring cars.
Scottrik is offline
Old 10-02-2010 | 07:58 AM
  #34776
andrewdoherty's Avatar
Originally Posted by CypressMidWest
All depends on what you're looking for.....
1. Will reduce the cars tendency to rotate, and will reduce exit steering on power
2. Will give you more forward bite, reducing exit steering on-power
3. Will add side bite, making the car slightly more stable, but more prone to chunking
4. Rake will make the car turn-in less aggressively off power
5. will add side-bite untill you reach the point of diminshing return by going too soft.
6. Slows weight transfer, will make the car less reactive
7. Whites are in general too soft, good forward bite, but lacks side bite. try yellow or grey
8. I never do this, as it really only affects the car at high speeds
9. slows longitudinal weight transfer. You don't really give up overall steering, but you will lose some turn-in
10. If you're normally running Speed 8's this body offers more grip everywhere.
11. I'd actually move the forward mounting point further forward if possible, though I haven't played with this adjustment in years.
HTH.....
andrewdoherty is offline
Old 10-02-2010 | 02:31 PM
  #34777
spring71's Avatar
Smile
Pre-Signup for the 1st TQ Pan Car Grand Prix.
You will get one more raffle ticket for the pre-signup.
Click Here for Pre-Signup
Thanks.
spring71 is offline
Old 10-02-2010 | 04:19 PM
  #34778
Default Chassis balancing question
I know this has been answered before but I'd like a couple more opinions. For the record, I'm only asking because my search results yielded 2 answers and I'm looking for a definitive answer
I've got an L4 and I'm getting ready install a 1s pack and the rest of the electronics. I have tinkered around with which side to mount the electronics and it seems that if I balance the entire chassis with the motor installed, I should mount the battery on the right side of the chassis and the electronics on the left. But, if I look at how weight is distributed on the chassis and with the goal in mind of adding as little weight as possible, I feel like I should mount the battery on the left (2/3's of the servo is on the right side of the chassis).
My question is: should I balance the entire car (pod and chassis) or just the chassis but with the motor wires where they would normally be? Thanks!
adam lancia is offline
Old 10-02-2010 | 07:48 PM
  #34779
LonnyJ1950's Avatar
Balance the entire car. Be sure the T-Bar is level side to side, if possible back off the tweak screws so there is no tension to affect the balance. If you're serious about the L4 consider a 1S split pack.
LonnyJ1950 is online now
Old 10-02-2010 | 08:11 PM
  #34780
odpurple's Avatar
Originally Posted by adam lancia
...My question is: should I balance the entire car (pod and chassis) or just the chassis but with the motor wires where they would normally be? Thanks!
You're not going to get a definitive answer because this has been discussed at length and people dissagree.
On a car like the L4, which was not designed for brushless motors, you should balance the chassis by itself. The reason is that the BL motor makes the motor box heavy on the left (non-gear) side. So if you balance the whole car you will add extra weight to the right side of the chassis to compensate. But with tires on the car and it sitting on the track that extra weight is pushing down on the right front tire more than the left. The motor pod does not come in to play because it sits level on the rear axle. I believe the disagreement may come from the fact that it makes little difference which way you do it as long as the car is not hugely out of balance.
What does make some difference is that you will have to add a lot of weight to the electronics side of the car to compensate for the battery, and the car will be quite overweight. Most of the cars these days can weigh in around the minimum so that can be a disadvantage. Like Lonny said, you should just get the excellent Speedzone 1s saddle pack. It will fit with little to no modifications and you'll have no balance issues (from the battery at least)
odpurple is offline
Old 10-02-2010 | 08:34 PM
  #34781
+1
Old 10-03-2010 | 03:36 AM
  #34782
Thanks OD
Old 10-03-2010 | 11:01 AM
  #34783
Guest
Default body help????
I am looking for a body for a crc 1/12 I need help? What do I need to get. I been looking at the 4167 black art Audi rc8 from crc with the cockpit.??
LOSIRACER77 is offline
Old 10-03-2010 | 11:11 AM
  #34784
whynot's Avatar
that's a good body, Alot of guys use the parma speed 8 also.
whynot is offline
Old 10-03-2010 | 11:19 AM
  #34785
Guest
[QU!
!OTE=whynot;8018471]that's a good body, Alot of guys use th
That is what I had raced 3 years ago but didn't kknow what was working on the crc cars??
