I need some tuning help on a OS VSPEC >
Old 09-28-2010 | 03:13 PM
  #31
Originally Posted by JoeC
With the help of all of you I have gotten the high rev down to 6 seconds before perfect idle and on the pinch test it dies at about 6 seconds. Buggy runs great now but i am going to replace the tank again just to make sure that is not causing a problem. Should the engine idle down right away or does it normally take a few seconds? I still think there is a problem some where but for now I will keep trying to fine tune.
Cool, I had a problem with my Losi today where it would idle high and I couldn't get it. I ended up starting over from some base settings I know are good enough to run, but not dialed in. After a few minutes it was running great again.
Dredd is offline
Old 09-28-2010 | 04:27 PM
  #32
pitpop's Avatar
I find it ironic that this thread is RIGHT NEXT to the OS engine thread... (or at least it was until I posted)
pitpop is offline
Old 09-28-2010 | 04:29 PM
  #33
jpalessi's Avatar
jpalessi is offline
Old 09-28-2010 | 04:39 PM
  #34
I find it hilarious that some are trying to keyboard diagnose the guys problem and then arguing with each other about it when clearly the fix was in the first few postes. Bandwagon-ers on the first few postes
got_nitro is offline
Old 09-28-2010 | 05:14 PM
  #35
What I find funny is when someone posts "I have a problem with my engine." There are people who jump right to "you have an airleak! take everything apart!". Most of the time it's just wrong tune. Starting over and reworking it will usually take care of it, especially if it's all new gear.
Dredd is offline
Old 09-28-2010 | 05:26 PM
  #36
That wasn't me and I agree, you see that crapin'in all the time.. Air leaks are over rated.
Old 09-28-2010 | 05:52 PM
  #37
pitpop's Avatar
what would blow me away is to fix an engine problem on a chat forum!
pitpop is offline
Old 09-28-2010 | 06:31 PM
  #38
Actually adjusting the mid range with the lsn and idle helped. I may be new to nitro but I can work on anything and understand mechanics very well. I like to ask questions when something is new instead of just assuming something and then blowing up a new engine. All the suggestions have helped and I hope after tomorrow it will be all good. Thanks for everyones help.
JoeC is offline
Old 09-28-2010 | 06:38 PM
  #39
Hey in the end regardless of what anyone says this is a hobby. Hobbies are meant to be fun and enjoyable. As long as you enjoy R/C then all is good.
pitpop I understand what you're saying, but there are some very common mistakes that people make with Nitro engines. These mistakes have easily recognizable results (high idle, won't idle, bog at wot, bog at low throttle etc). Those problems can be diagnosed through trial and error and someone who doesn't know what causes a particular condition, would do well to ask for advice on things to try. If it doesn't work you can always turn the needle back to where you had it and try something else.
Dredd is offline
Old 09-28-2010 | 06:52 PM
  #40
The biggest thing that I have learned with nitro so far is how small adjustments can make a real difference in tune. I printed off the tuning bible as well as all of your post and it helped alot. Thanks again to all who have posted.
JoeC is offline
