Associated RC12R5 >
Associated RC12R5
Associated RC12R5
Old 08-06-2010 | 02:33 PM
  #2371
tiko's Avatar
Originally Posted by SUV-ETR
Sometimes the front springs sag, so that's an easy thing to try and replace.
If it is more off than that, I'd take a close look at the plastic parts in the front end. Try swapping the arms and see if things change. I did have one arm that came with a slight bend molded into it. Couldn't see it with your eye, but it threw the ride height off at the back by nearly 1mm. Also make sure your chassis plate is flat.
Neal
Thanks Neal, my ride height is off about 1mm in the back it could be more. I'll give the front springs a try too.
Tiko
tiko is offline
Old 08-17-2010 | 03:13 AM
  #2372
Default Hébert dominates 1/12 Open class at ROAR Nats
http://www.redrc.net/2010/08/hebert-...s-at-roar-nats
M.Abramowicz is offline
Old 08-17-2010 | 03:18 AM
  #2373
defcone's Avatar
Originally Posted by M.Abramowicz
Where can we find setups?
defcone is offline
Old 08-25-2010 | 12:17 AM
  #2374
darrenoakley's Avatar
Does anyone know if the rear pod from the 5.1 will fit on the 5 and if so what would the benifit be in doing this ?
darrenoakley is offline
Old 08-25-2010 | 11:03 AM
  #2375
AE-Reedy
Yes it will but you have to change the graphite pieces as well.
The main benefit is easier access to the motor and better weight distrubution left/right with BL motor.
Sean Cochran is offline
Old 08-25-2010 | 11:50 AM
  #2376
Cheers for that, Wanted to check before going any further
Old 08-25-2010 | 02:26 PM
  #2377
AE-Reedy
Keven's set up has been submitted to the website.
Should be up no later than tomorrow.
http://67.199.85.166/racing/setups.php
Old 08-25-2010 | 02:36 PM
  #2378
niceeeee
Chase1472 is offline
Old 08-26-2010 | 01:02 AM
  #2379
boscoj's Avatar
Default Hey you freaks . . . trying to upload some RC12E/L/12 luv pics
bbiab
Chassis?
Yups . . .
boscoj is offline
Old 08-28-2010 | 12:31 PM
  #2380
Wow them pics bring back some great memory's .
Ahh the good old days.
Originally Posted by boscoj
bbiab
Chassis?
Yups . . .
Mike Blackstock is offline
Old 09-02-2010 | 08:03 PM
  #2381
ok, Im new to 12th scale and onroad in general. I got a used 5.1 and its time to rebuild the center and side shock. I pulled up the manual on ae's website and it didnt get me much on proper building. I am wondering what is the best way to buils/bleed these shocks? thanks
micrors4guy is offline
Old 09-02-2010 | 08:31 PM
  #2382
I hate to say this but the way the manual shows it is the best way to build them. Best tip is to go slow and be careful not to crossthread the caps. Fill them all the way up with oil and wipe off the excess after putting on the caps.
AreCee is offline
Old 09-02-2010 | 08:36 PM
  #2383
ok just didnt know if there was a certain amount of oil to put in them or what. so basicly full them drip the oring on and cap it?
Old 09-02-2010 | 08:44 PM
  #2384
AE-Reedy
Be sure to use fresh o-rings when you do the re-build. That helps a ton. It is almost impossible to re-use the o-ring after it swells.
Old 09-02-2010 | 08:47 PM
  #2385
im going to but the full rebuild kit to get the orings and new ends.
