FW05R or V-1RR Evo
Old 03-19-2004, 04:34 PM
Ares17's Avatar
Default FW05R or V-1RR Evo
Need help with making the decision for my next 1/10 nitro. Factors affecting decision should be top end speed, ease of maintanence, Lola shell fitment. Any inputs from owners of both or either cars will greatly be appreciated. Thank you.
Ares17 is offline
Old 03-21-2004, 06:43 PM
vones's Avatar
FW-05 n V1-RR EVO both are good cars....the only thing is the driving style of the cars
you need to know your driving style,
top end speed depends on gearings, if you want pick up, you'll lose out on top end speed n vice versa.
in terms of maintenance both cars are pretty much the same its just by removing the radio deck. On the FW the radio deck is very simple n the electronics(steering n throttle) are mounted on it. once you remove the deck you can access everything. maintenance is mostly on the frnt n rear bulkheads. The crown gears n pinion. Shimmimg is very critical.
For EVO the layout looks messy is compare to FW but still the ease of maintenace is still acceptable. Bear in mind both are nitro cars ...oil n dirt are always present. Both cars can be fitted with Lola body. The only thing I hate abt the 05 n EVO is the 0.8 pinion gears. They wear out too fast. That's why I'm still using the 1.0 gears. I hve tried both cars n I find that the 05 is not my cup of tea. reason being I'm the type who like to squeeze throttle any chance i get n brake hard to take corners. 05 need more sensitive fingers....the more experience drivers would like this car. I still stick to my evo. There's a race coming up this Sunday 28-March at HPRC sembawang. There will be a lot of different cars, so you can drop by n see for yourself.
vones is offline
Old 03-21-2004, 06:45 PM
vones's Avatar
BTW way 05r is shaft driven the stock internal gear ratio is 3.07......evo(belt drive) is 2.526. the bigger the gear ratio the better the pick up.
vones is offline
Old 03-21-2004, 06:57 PM
F&K
F&K's Avatar
Hi vones,
Are you using the 1.0 gears with Centax Clutch? Is the 1.0 gears, pinion gear housing the same with the Centax Clutch pinion gear housing?
F&K is offline
Old 03-21-2004, 07:03 PM
vones's Avatar
Hi vones,
everything the same..... the centax, the 2 speed changer....just remove the 0.8 gear(spur n pinion) and fit in the 1.0 gears.
vones is offline
Old 03-21-2004, 07:07 PM
vones's Avatar
Hi vones,
ONE MORE THING...only the V1-RR evo can use the 1.0 gearing...the FW-05 can only use the 0.8 gear
vones is offline
Old 03-21-2004, 07:35 PM
apmk's Avatar
Default Hardern gears
Hardern 0.8 pinon gears are out, give it a shot guys.
apmk is offline
Old 03-22-2004, 07:23 AM
Vones....kindly check your PM
Joop is offline
Old 03-22-2004, 07:55 AM
orangbaligila's Avatar
aaahhh,... I was about to search for the 1.0 spur for 05R,... hehehe,... I think thez should make it (Kyosho),... I don't need so much smoothness compared to longevity,...
orangbaligila is offline
Old 03-22-2004, 07:57 AM
Default Re: Hardern gears
part number pls,.. looks like I'm gonna stock piles of 'em (when proven hard enough)
Old 03-23-2004, 05:45 PM
Ares17's Avatar
dun quite understand 0.8 or 1.0 pinion. wat do the number describe?
Ares17 is offline
Old 03-23-2004, 06:10 PM
Hi Vones....U hve PM
Joop is offline
Old 03-23-2004, 06:36 PM
vones's Avatar
the new pinion gears (0.8 module) tat came out by Kyosho n mugen the fine teeth type usually from 20 teeth to 29 teeth..if I remember correctly...the old pinion gears(1.0 module) tat exsisted till today comes in 15 teeth to 22 teeth.
vones is offline
Old 03-25-2004, 06:23 PM
Default fw 05 r harden pinion gear
Any body have the parts number for the kyosho harden pinion gear??
josephtiong is offline
Old 03-25-2004, 07:27 PM
Joehwee's Avatar
Hi guys: I think the harden pinon ampk are refering to are not from Kyosho but from Active. Hobby Bug have them in stock.
Joehwee is offline
