The New Werks B5 .21 Racing Engine >
Like Tree63Likes
Old 07-28-2010 | 02:45 AM
  #4831
I simply just wanted an explanation to a comment, I come in PEACE,, I even thanked the guy for coming in on the thread! Was in noway trying tobe brutal. I should've known better and sent him a PM.
justag3 is offline
Old 07-28-2010 | 02:56 AM
  #4832
pete31's Avatar
Hi guys,
Just wondering if anybody has tried the thunder tiger 2039 pipe with this engine and how it performed with it?
Cheers
pete31 is offline
Old 07-28-2010 | 10:18 AM
  #4833
Never tried the 2039. as far as pipes go try it and see how it works, there are so many pipes out there these days it can take a year to try them all....lol I just stick with what is made for the engine. Then you know you are getting the best mileage and power.
heidmann1 is offline
Old 07-28-2010 | 10:52 AM
  #4834
mike881's Avatar
Hey Ron so I ordered a 2nd B5 and I'm going to break it in today. In your tuning bible I'm a tad confused. Do I start out with the idle screw 1.5 turns in from flush or start with 2.5 mm? Also do I start with the low end screw flush as well?
mike881 is offline
Old 07-28-2010 | 12:53 PM
  #4835
justag3 is offline
Old 07-28-2010 | 02:05 PM
  #4836
Bengsch85's Avatar
On the new carb 1.5 turns in from flush should get you right about 2.5 mm. You can start flush on the low end but with the wide gap you should have to richen it up from there for the break in.
Bengsch85 is offline
Old 07-28-2010 | 02:29 PM
  #4837
justa, i have read the last 2-3 pages of this thread over and over and cant find any fault in your question. Why fellow racers would laugh at you and or your question, i just dont understand! In your defense i feel you deserve a public apology.
RU-SERIOUS is offline
Old 07-28-2010 | 06:27 PM
  #4838
I just want to take a second to address this so we can get this thread back on track. I explained the same thing to justag3 in a PM but my post was not intended to poke fun at him or anything else all that I was saying is that these forums can be brutal at times because people misconstrue and/or take your comments the wrong way. So again there is no reason that a single person should feel uncomfortable posting anything on here, if anything this is probably one of the best threads on here as far as people getting their questions/concerns addressed in a helpful and courteous manner. Hope that helps clarify my take on things!
Regards,
Ron
Werks is offline
Old 07-28-2010 | 06:31 PM
  #4839
Now on a more positive note for all of you that have expressed interest in our new "Pro Clutch" system I'm happy to say that they are in stock and available at A-main now! Follow the link to find them:
http://www.amainhobbies.com/index.ph...&filter_mfr=30
The 34mm diameter flywheels fit the vast majority of the vehicles. The 32mm flywheels fit the X-Ray, Jammin, Kyosho and also can be used on the HB buggy!
Results in testing on these has been awesome, frankly they are every bit as good as our engines so if you given those a shot and liked them I'm 100% confident that you will feel the same way about our "Pro Clutch" also!
Werks is offline
Old 07-28-2010 | 06:50 PM
  #4840
VWVR6_T's Avatar
Do you have a thread just for the clutches? if not, What make this clutch different from the Losi? I see you have heavy,med., ligh 34mm and the same in 32mm. Just to makes things clear, I'm looking for information, nothing more nothing less.
VWVR6_T is offline
Old 07-28-2010 | 07:39 PM
  #4841
vypr2002's Avatar
I am really blown away at the small airgap you say to use ron. .5mm seems SOOOOO small compared to what I have been running for years.
I havent had the chance to tune with your system yet, Ill get to it this weekend. Looks like Ive been tuning wrong since the begining!!!! I love all the info you put out and the fact I have learned another new thing in this hobby.
vypr2002 is offline
Old 07-28-2010 | 07:48 PM
  #4842
Ran my 14th tank today thru the B5. Got it at around 220F on the pavement. Most all the metal pinch is now gone. Motor has been a breeze to break in and tune tho i do have one question to run by you.
My idle gap is about 5. or .6mm. High speed needle tuned to about 220F. Low speed is just barely in from flush. It idles good but pretty low. After a high speed run it will idle slightly high then a few seconds later drop to the pretty low idle. Is that correct? I don't think the slight high idle for a few seconds is high enough to cause a run on but i haven't had it on the track yet either. Any input?
bacchus is offline
Old 07-28-2010 | 08:07 PM
  #4843
VWVR6_T's Avatar
Wait till you get the buggy on the track, tune in pavement is not the same as tune in dirt, you will find out that you have to lean a little bit more once you are in the track, why? the engine doesn't do the same effort than in the dirt. GL
VWVR6_T is offline
Old 07-28-2010 | 08:10 PM
  #4844
mrbusta's Avatar
fat botom idel gap 2 much
mrbusta is offline
Old 07-28-2010 | 08:15 PM
  #4845
VWVR6_T's Avatar
how this .5 - .6 mm is too much? That is what everyone with this engines use. Can you explain why?
VWVR6_T is offline
