Go Back  R/C Tech Forums > International Forums > Australian Racing > XRAY Australia
1:10TH EP Onroad Setups & Discussions >
Rate Thread
Old 05-26-2012 | 05:11 AM
  #91
MrRolla's Avatar
Originally Posted by defcone
Here is my setup from the Muchmore masters.
Keefy,
Any reason you use HPI springs over the Xray springs? Seen alot of people using HPI springs..
MrRolla is offline
Old 05-26-2012 | 05:19 AM
  #92
defcone's Avatar
Originally Posted by MrRolla
Keefy,
A bit more aggressive when compared to same hardness xray, felt the car was too easy to drive.
defcone is offline
Old 05-26-2012 | 05:47 AM
  #93
MrRolla's Avatar
I might have to give them a try, a bonus is they are much cheaper than the Xray equivalent..
MrRolla is offline
Old 07-31-2012 | 03:01 AM
  #94
hmmm...
highslide is offline
Old 08-07-2012 | 05:02 PM
  #95
narcotiks's Avatar
With the new progressive springs(2.2-2.6) with the writing on the spring facing up do you have the soft compression first or the hard compression first?
Put the progressive springs on all around with writing facing up and it seems to be less responsive and have less steering than 3.0 at the front and 2.6 at theback
narcotiks is offline
Old 08-07-2012 | 06:37 PM
  #96
nerdling's Avatar
The soft part of thew spring will allways compress first, regardless of the orientation of the spring.
[/QUOTE]
Put the progressive springs on all around with writing facing up and it seems to be less responsive and have less steering than 3.0 at the front and 2.6 at theback[/QUOTE]
That would tally, you have dropped your spring rates down to 2.2 for the initial movement with a maximum of 2.6 has the springs reach maxuimum compression. Softer springs will feel less 'direct'. but yeild more grip.
nerdling is offline
Old 08-07-2012 | 06:56 PM
  #97
narcotiks's Avatar
That would tally, you have dropped your spring rates down to 2.2 for the initial movement with a maximum of 2.6 has the springs reach maxuimum compression. Softer springs will feel less 'direct'. but yeild more grip.[/QUOTE]
Would my setup be more successful if i used 2.6 or 2.8 at the front with the progressives at the back?
Old 08-09-2012 | 03:33 AM
  #98
nerdling's Avatar
Would my setup be more successful if i used 2.6 or 2.8 at the front with the progressives at the back?[/QUOTE]
It would be worth a try.
nerdling is offline
Old 12-02-2012 | 04:18 AM
  #99
Shev's Avatar
Can you buy all the springs for the t4 as a set?
Shev is offline
Old 12-02-2012 | 05:46 PM
  #100
OLD 69's Avatar
Company Representative
Not as a set they come as pairs.
...Ari
OLD 69 is offline
Old 12-03-2012 | 12:13 AM
  #101
Shev's Avatar
Thanks Ari. I stepped out today and ordered a T4. I'm officially with team Xray.
Shev is offline
Old 12-03-2012 | 02:58 AM
  #102
OLD 69's Avatar
You will love it mate, build it to kit setting and run it.
Ak here if you need any assistance.
...Ari
OLD 69 is offline
