Go-Tech Engines Thread
Thanks bigmatt for pointing me in the right direction with my tuning issues that were burning out glow plugs after 10 minutes.
I followed settings and tweaked from there.Still getting plenty of smoke and running much stronger.
thanks again......gosharpie97.
P.S. -Gonna hold on to engine for a while,but YOUR first on list when I sell.
LOL.
LOL.
LOL.
LOL.
I'm trying to squeeze as much as possible out of this nice 3PT Racing... the sleeve already got some nice ports on it.
Fill some epoxy in the crankshaft... do you all do this mod?
Am i filling too much?
will try the engine on this weekend...
Just bought RC8T with a Go .21-spec-3port engine with red head on it.Running 30% Sidewinder fuel.I'm new to these engines and am having issues and getting fustrated.After buying,I tore it down cleaned checked and rebuilt everything in the power plant.First off it starts great and idles fine.I'm having problems getting the temps up, I lean it out to get temps up and it seems to be starving for fuel and stalls out.Richen it up a little and it runs fine but after about 10 minutes temps only at 160 F it pukes the O'donnell 97T plugs that I'm using.The plugs are still clean and new looking but the wire is breaking about 2-3 coils up in the plug.
I'm hoping this is enough info for some help/suggestions with my problems.
thanks............gosharpie97.
Any of the GO dudes attending the RC PRO Series Florida this saturday at Fort Lauderdale ?
Im in USA for job assignment, just 5 days and i got my car with me to hang out at the track, will be arriving to the track just saturday right before qualies ... would love to put some faces on the forum texts ...
cya !
cya !
Rex
yup...no lightening process, i just added epoxy to make the ram, i thought its for better flow of the fuel. no? i thought i saw a few top race engine got epoxy as a ram...
Those are also lightened and then ramPed. A "ram" would be more of a scoop out side the engine, forcing more into the carburetor. The technique has more to do with removing excess metal and then providing a more linear line for the fuel/air mixture.
You cannot push mixture, a ramp does not aid flow in any way at all, if anything it disrupts flow...... mixture always takes the shortest path naturally, it cannot be pushed or pulled...... The filler in the crank just reduces crankcase volume and nothing else....
using this logic, port size, number, design, and surface smoothness would have nothing to do with airflow. This is incorrect.
mixture takes the shortest path... the closer you can make that path to a straight shot the better...removing obstruction from the path is all you can do....you cannot push a gaseous mixture, a ramp does not guide the mixture, all a ramp does is fill empty space which decreases crankcase volume, which increases crankcase pressure on the pistons downstroke, which aids in the transfer of mixture from the crankcase tot he combustion chamber.....
Once again the mixture naturally takes the shortest path, from high pressure to low pressure...we cannot guide the mixture, all we can do is give it an easier route... removing any bends in the shortside radius is far more effective then trying to add material to the outside radius !
However since we cannot help but for the mixture to make contact with surfaces inside the engine, we can reduce the surfaces interference by slightly texturing the surface...A textured surface actually flows better then a smooth surface ! 220 grit finish flows better then mirror smooth !
in this case, both aerodynamic and fluid dynamic laws apply here. Smooth surfaces have less drag coefficient, due in part to reduced turbulence generation and reduced exposed surface area. The only advantage that a less smooth surface could provide would be increased atomization. Due to the velocity of the air moving through the engine at operating speed, this is a moot point. The vaporization point of nitromethanol in a vacuum environment (carburetion) is typically below the operating temperature of these engines anyways. This will vary, based on lubricants and additives.
Lastly, from the point of entry (carb venturi) to the cylinder, the fuel/air mixture is under vacuum. That is unless you're running forced air induction (supercharger). So, the mixture is being pulled- not pushed.
2Likes
