The Speed Passion Thread >
Like Tree57Likes
Old 05-20-2010 | 03:55 AM
  #4381
AGNO's Avatar
"Unfortunately, there is a Bug in FW 100422 DDRS, can be solved?"
Originally Posted by charlie_b
DDRS we leave it at 8 or 9. Reason being, with the Supercharger software, we now control punch with SC Punch #15. If you want more punch, lower your parameter on #15. All these settings relate to each other. If you turn down DDRS too low, SC Punch will not be activated.
The bug has been fixed.
AGNO is offline
Old 05-20-2010 | 07:33 AM
  #4382
stinky cheese's Avatar
Default Help
Need some help,I downloaded the new software and have it installed on my speedie but my LCD progammer still has the 225 software on it so I can not use the LCD programmer to change my settings, it works via the pc though. Any suggestions are welcome.
When I try to use the lcd programmer it comes up with a please update software message.
stinky cheese is offline
Old 05-20-2010 | 08:58 AM
  #4383
Abu Salahuddin's Avatar
The new supercharger firmware will not work with the lcd programmer. Use the original program card that came with the esc. All 15 settings will then be made available with it.
Abu Salahuddin is offline
Old 05-20-2010 | 09:29 AM
  #4384
Ritchie T's Avatar
Exclamation
I thought you update the programmer to 1.05 and it does?
Ritchie T is offline
Old 05-20-2010 | 09:33 AM
  #4385
charlie_b's Avatar
Super Moderator
Actually, the LCD card DOES work with the new software. You can download the new V 1.33 USB Interface Software at SPEEDPASSION.NET
Included is the 100422_STOCK, the 09205_MOD, and the 100508ZERO.
charlie_b is offline
Old 05-20-2010 | 03:13 PM
  #4386
xrayal's Avatar
on the OTHER THREAD, a new 518software has been released, apparently sorting out the BUG. is SP going to update or bring out something similar to erradicate the bug also?
xrayal is offline
Old 05-20-2010 | 04:35 PM
  #4387
Default HELP
Thanks,
The old standard box which comes with the speedie works so I can now change settings with out my pc,is there a way to make the newer 2in 1 box work as well.
Old 05-20-2010 | 05:17 PM
  #4388
charlie_b's Avatar
Super Moderator
I am not even aware of any "BUG" when using the Supercharger software, we leave DDRS at 8 or 9. In fact, even when we did not have the supercharger software, we never went below 8. Anything below 8 is Useless...
Old 05-20-2010 | 05:20 PM
  #4389
skypilot's Avatar
skypilot is offline
Old 05-20-2010 | 05:54 PM
  #4390
Originally Posted by stinky cheese
Thanks,
Yeah there is Cheesy how about you read up abit
When you plug in the lcd box if you click on device a drop down box will show
ESC speedcontroller
Motor Function Checker
LCD program unit
Click on LCD program unit and it should say somewhere there about update click on that and all should be well.
Run the upgrade a few times to make sure all goes in.
Otherwise ask Sandy at your work he knows what to do.
bjspinner is offline
Old 05-20-2010 | 06:25 PM
  #4391
Thanks,
Yes, please read Charlie B's post. There is a new firmware released by sp a week ago. This should make the lcd programmer work.
Old 05-20-2010 | 06:49 PM
  #4392
Joel Lagace's Avatar
Is there an updated USER GUIDE/SETUP GUIDE out for this new software? Something that would tell us that DDRS should be at 8 or 9?
I ran it last nite in my buggy and it was pretty good but i could have used a bit more bottom end, i was using DDRS at 7.
Joel Lagace is offline
Old 05-20-2010 | 07:05 PM
  #4393
Default HELP
Thanks to those for their input, I managed to update my older 2in1 programmer but the newer one with the software ending in 255 will not let me update to the 420 software. Cheese
Old 05-20-2010 | 08:02 PM
  #4394
mr crum's Avatar
bump it up to 9 watch your temps
mr crum is offline
Old 05-20-2010 | 08:04 PM
  #4395
mr crum's Avatar
+1 even with the old 1.1 version speedos we always jacked drrs to #9
mr crum is offline
