The Speed Passion Thread >
Like Tree57Likes
Old 04-03-2010 | 05:45 PM
  #3661
same thing here, no matter what combination of fdr, motor timing & supercharge s/w parameter it just can't match tekin rspro / lrp ssx ss, the gap is obvious both on infield & top speed and yet they still have cooler motor temp
i still hoping that the upcoming new firmware will address these "issues"
Originally Posted by RTR canada
im running a 7.7 FDR and i have tried all gears and modes on the turbo software and at this point there is no way i can keep up with the Tekin. The infield power is not so bad but when you get on the straits they make me look dog slow. Im running t2009 and Sp pro esc and 3.0. If anyone has any ideas other than getting a Tekin please let me know. Thanks
leonardiw is offline
Old 04-03-2010 | 06:08 PM
  #3662
smilekt's Avatar
what turn motor ?
smilekt is offline
Old 04-03-2010 | 07:25 PM
  #3663
dbmartin's Avatar
Does anyone have a SP programmer for sale, or know any sites in the US that have them in stock.
Thanks.
dbmartin is offline
Old 04-03-2010 | 07:36 PM
  #3664
CraigM's Avatar
Can someone suggest a timing setting for SP v2 5.5 with a GT2.0 Pro? using 323 software
thanks
Craig
CraigM is offline
Old 04-03-2010 | 07:50 PM
  #3665
Marcos.J's Avatar
Super Moderator
Thanks.
Hey Dave I should have one with me for the state race and I will also will have my laptop with me
Marcos.J is offline
Old 04-04-2010 | 09:06 AM
  #3666
razzor's Avatar
thanks
Craig
std in the center is best.
razzor is offline
Old 04-04-2010 | 12:44 PM
  #3667
jw_rooster's Avatar
any ideas on a FDR for 2wd buggy with a GT2.0 and a V3.0 13.5 and 8.5? with my Novak 13.5 I am running a 7 FDR and it is pretty good there, but I have heard the 3.0's like more pinion. Thanks
jw_rooster is offline
Old 04-04-2010 | 02:26 PM
  #3668
heavy's Avatar
On item 15 my value adjustments only go as far as 6 when I believe they should go through 9. Can anyone confirm they have more than 6 on item 15.
heavy is offline
Old 04-04-2010 | 02:35 PM
  #3669
Stein Tumert's Avatar
Correct, the beta sw only goes to 6....
Stein Tumert is offline
Old 04-04-2010 | 06:51 PM
  #3670
xraysteve's Avatar
Foregive me if this has been posted already. I looked and could not find the answer. Is the new software out that uses the turbo or is it just being tested?
xraysteve is offline
Old 04-04-2010 | 07:54 PM
  #3671
skypilot's Avatar
it is out, look back on page 203 or so of this thread, be sure to read the next few pages theres good info in there
skypilot is offline
Old 04-04-2010 | 07:56 PM
  #3672
skypilot's Avatar
thanks
Craig
i ran mine at center on can, and 18.75 on the box for the gt2 can't remember the gearing, 7's maybe, pretty large outdoor track
skypilot is offline
Old 04-04-2010 | 08:16 PM
  #3673
defcone's Avatar
Any suggestions for a LRP x12 5.5t? On a technical track with a 30-40m straight?
defcone is offline
Old 04-04-2010 | 08:51 PM
  #3674
With 13.5 I was around 6.5fdr with max timing.......but that was before timing boost....I think I was running the 107 software
8.5 I'm around 8.4fdr
In a losi 2wd
clintscreations is offline
Old 04-04-2010 | 08:59 PM
  #3675
jw_rooster's Avatar
In a losi 2wd
thanks, that should be a good starting point then because our internal ratios are pretty similar. I thought my Novak FDR would be pretty close, but just wanted to make sure.
