R.A.B. Hobbies
#35
NOVATECH 3000kv MOTOR ESC COMBO
Motor and ESC combo for parking lot bashing. Great value with very good quality.
MOTOR : 3000kv
INPUT: 7.2v - 7.4v (NiMh, NiCd, LiPo)
OUTPUT: MAX 360W/40Sec, <4500kv MOTOR (1/10 CAR)
FET: 60A (@25c) OR 54A (@75c) UNDER GOOD VENTILATION
DIMENSIONS: 46MM X 28.8MM X 31.5MM WITH FAN
WEIGHT: 66g (WITH WIRE, CONNECTOR & FAN)
Cheers
Ren
MOTOR : 3000kv
Cheers
Ren
#36
ISHIMA RAVE M1.OS NOW IN STOCK.
RAVE M1.0S
Ready To Run 1/8th scale
Nitro powered buggy
Height : 160mm
Weight : 3380g
Length : 485mm
Width : 305mm
Cheers
Ren
RAVE M1.0S
Nitro powered buggy
Height : 160mm
Weight : 3380g
Length : 485mm
Width : 305mm
No Compromise!
Best performance 1/8th scale 4WD
“Ready To Run” racing buggy
The ISHIMA RAVE M1.0S is the entry-level version of the RAVE 1/8 buggy range.
Although we put the words “entry-level”, there is NO COMPROMISE been done. The RAVE M1.0S has the same performance in all conditions as the competition M1.0R version, only by using different production techniques we lowered the cost but not the performance.
The designers of ISHIMA RACING strove to have a strong, reliable and high performance 1/8 RTR buggy.
Cheers
Ren
#37
EXOTEK RACING TC5 PARTS DUE IN END APRIL.
(TC5XX CHASSIS FROM FIRST ORDER SOLD OUT)
NEW STOCK ARRIVED TODAY : 14/04/10
MORE TC5R PARTS
EASTCOAST M6 SPEED 09 SPEC BODIES
REEDY 121VR MOTOR
LOUISE RC TRUGGY PIT BAG
TEAM C RACING RTR BRUSHLESS KITS
STARMAX ELECTRIC ARTF JETS
ACE RC 11.KG METAL GEAR STEERING SERVO
VENOM STOCK ARRIVED INC PIT BAG BODIES & ACCS
MUCHMORE 32 SHORE MOUNTED TYRES
CHEERS
REN
#39
MINIDV - MINI DV VIDEO RECORDER
ACCESSORIES INCLUDED IN PACKAGE.
CHEERS
REN
- ULTRA SMALL
- PC CAMERA
- AVI OUTPUT FORMAT
- VOICE ACTIVATED TRIGGER
- VIDEO OUTPUT 720 X 480 30M FRAME/SECOND
- 2 HOUR USE FROM INBUILT 260MAH LITHIUM BATTERY
- 2G MINI SD CARD INCLUDED. CAN USE UP TO 8G.
- MINI USB CHARGING AND COMPUTER CONNECT
- SOFTWARE INCLUDED.
CHEERS
REN
#41
NEW STOCK ARRIVED TODAY : 21/04/10
E FLITE BLADE MSR SPARES
HYPERION 6060i ACDC CHARGER (GREAT ALL ROUND CHARGER)
HIMOTO HEX SETS AND CAR STANDS (INTRODUCTION PRICES WILL NOT BE REPEATED ONCE CURRENT STOCK IS SOLD OUT)
HYPERION SWIFT 5C CHARGE LIPO HARD PACKS
BLUEBIRD ELECTRIC PROPS
ELECTRIFLY MOTORS & ESCS
WAYPOINT ESCS
NEW YEAH STOCK ARRIVED
CHEERS
REN
WAYPOINT ESCS
CHEERS
REN
#43
WHILE STOCKS LAST ALL ROAR APPROVED YT-90068 YUNTONG 5000 40C 7.4V HARD CASE PACKS WILL BE REDUCED IN PRICE. EITHER IN STOCK OR VIA FORWARD ORDER UNTIL FURTHER NOTICE.
QUALITY PACKS AT A BETTER PRICE.
CHEERS
REN
REN
#44
SOLD OUT! NEXT ORDER DUE IN MIDDLE JUNE.
Introducing the Exotek XR3.
A no holds barred multi-adjustment lipo chassis. With the unique cnc manufactured stainless steel weights your lipo battery can be positioned to have equal left and right balance within grams without the need to add lead weight and without raising the battery up higher.
CHEERS
REN
CHEERS
REN
