The Speed Passion Thread
#3376
It happened to me when I was running the timming at 4/11.25 deg.
It was impressive though just felt it could do with more punch on the bottom end (low RPM ) and more track time.
For the offroad guys this is what I ran with.
10.5 speedpassion version 2
1-1
2-2
3-4
4-8
5-3
6-4
7-1
8-1
9-4
10-1
11-1
12-9
13-4
14-6
15-6
Gearing 23/76 2.6 to1 gearbox, temps motor and speedy around the 60 deg celcius. 30 deg ambient temp
#3377
il be there bright and early with bells on around 7 to get a good spot
#3379
#3380
#3382
Hello,
This should be the last update. Some setup has been fixed with the correct name.
Have fun.
Download Link: http://www.megaupload.com/?d=CTJQ3TLY
Have fun.
#3383
Hello,
Have fun.
Have fun.
Here is what Adam's getting this weekend.
#3384
Yeh, I dropped this to 6 for some more smoothness, but the car was like a snail! and barely hit half throttle - i tried resetting the end points and re-calibrating, but nothing. So I just put it back up to 7 and left it at that.
#3385
Hello,
my Name is Oliver and i come from Germany. I drive a Xray T3 with Rubber Tires. I have Questions but my English is not so good.
I had load the new Beta Software with 231 but i donīt have drive with them. I tested on my table :-)
The RPM is very high on AMTS Timing 8, but i can not understand on #15 is 6 value but on the setup sheet it goes from:
Motor Hot Max
-1
-2
-3
-4
-5
-6
-7
Motor Cool Max
there are 9???
Is there a driver they had tested the Software with a Touring Car? with a 17,5 and a 13,5 Stock Engine?
What is the different about 230 and 231?
Olli
Motor Hot Max
-1
-2
-3
-4
-5
-6
-7
Motor Cool Max
there are 9???
Olli
#3386
Hello,
Motor Hot Max
-1
-2
-3
-4
-5
-6
-7
Motor Cool Max
there are 9???
Olli
Motor Hot Max
-1
-2
-3
-4
-5
-6
-7
Motor Cool Max
there are 9???
Olli
#3387
Hello,
Motor Hot Max
-1
-2
-3
-4
-5
-6
-7
Motor Cool Max
there are 9???
Olli
Motor Hot Max
-1
-2
-3
-4
-5
-6
-7
Motor Cool Max
there are 9???
Olli
I tried it with 13.5T v3 SP motor in TC.
230 is more agressive than 231 and produces slightly more power but I belive you'll have to keep an eye on temps more.
#3388
Hi
Just a quick question - probably more aimed at Shaun/Adam but if anyone else knows the answer that would be great
I'm at a race meeting this weekend, but along with actually running the meeting I'll be fairly limited on time to work on my car! I was thinking of trying the new software, but I won't have (another!) laptop to use to re-program my speedo.
What I basically want to know is, if I install software 230 onto the speedo but don't get the time to play properly with it and get it adjusted to my liking, can I then put Setting 12 (Boost Level) to "1" (Off) - will this then effectivly disable settings 13, 14 and 15 and act in the same way as if I was running software 107??
Many thanks for any advice
Oli
Oli
#3390
Hi
Oli
Oli
57Likes
