LiFe battery question
Interested in one because they last longer, safer, faster charge rates etc. Not sure but I would think it might effect servo speed due to the decreased voltage amount.
Has anyone used this type of battery in a TC car and what are results compared to lipo?
Everything you stated above is true, but for an RC application the battery poses a few issues.
The first is as you pointed out, it is not a voltage that is common with RC racing. If you don't race, then this will not be a problem. If you do, then you will be at a disadvantage running at 6.6v (2S) or a significant advantage running 9.9v (3S) and common rules for TC do not allow this battery.
The second issue is size. The standard size of the cell is not a sub-c. However, I believe that max-amps makes a LiFe package that can be mounted in most cars that can run a lipo pack.
LiFe batteries require a larger volume and mass than a LiPo of equivalent energy.
For a bashing around, I think LiFe is a fantastic technology with the quick recharge, safety advantage, less issues with accidental deep discharge, and high current discharge C capabilities. Just don't expect it to displace LiPo at your local race any time soon.
