Tamiya F103 Forum >
Tamiya F103 Forum
Like Tree9Likes
Tamiya F103 Forum
Old 02-14-2010, 08:26 AM
  #946
alana07's Avatar
Trader Rating: 53 (100%+)
has anyone tried out the TRG F103 rear rubber tires on a proper asphalt track? how's the performance like compared to Ride's rubber tires? seems like these F103 rubber tires are almost sold out everywhere, except Rcmart's left with the TRG's...
alana07 is offline
Old 02-14-2010, 09:29 AM
  #947
F N CUDA's Avatar
Trader Rating: 34 (100%+)
Originally Posted by InspGadgt
The pre-mounts in the 15th anniversary are HBR. I believe medium front and soft rear.
The pre assembled rears = the Super soft that used to be around.
The Super soft donuts that are similar to the premounts/pre assembled are the #84095.
Don't be confused by the letter C as it also appears on other tags.
The HBR soft rears are more firm than these.
The fronts are HBR Medium, premounts or the donuts.
So, the medium fronts and the super soft rears are the winning combo for everything I run on, carpet and asphalt.
Just sauce the fronts as necessary.
1/4, 1/2... or no sauce on the front all!
F N CUDA is offline
Old 02-14-2010, 09:31 AM
  #948
robk's Avatar
Trader Rating: 22 (100%+)
Originally Posted by Obsidian
So correct me if I'm wrong, Are the f103 15th anv. kit tires different from the other 2 available sets?
I would think that the premounts are just a tire that Tamiya already has, but I'm not sure. Maybe they are both mediums, since the soft HBR I have run act nothing like the premount rears-softs have a weird, sudden break away on carpet. At the same time, the HBR medium rears I have tried always seem too stiff Maybe they are RM "kit" tires? The fronts do seem close to HBR medium fronts.
robk is offline
Old 02-14-2010, 09:33 AM
  #949
robk's Avatar
I have never seen "super soft"- is there a number for those donuts?
signed Confused by Tamiya
robk is offline
Old 02-14-2010, 09:35 AM
  #950
F N CUDA's Avatar
I bought a set of the TRG Superion rubber tires.
Good grip on the rear, too good. PUSH bigtime at high speed but seem perfect at about 1/2 speed.
NOTHING would get these to steer at speed.
I even cut apart the fronts (around the sidewalls) and put softer foam inside.
This helped a lot but still not good enough.
Bought Rides and problem solved.
Wanna buy my Superions with the softer insert installed?
Like new!
Only about 10 minutes total run time on em, had to at least give em a chance to break in some before giving up on em.
F N CUDA is offline
Old 02-14-2010, 09:42 AM
  #951
F N CUDA's Avatar
The part number for the 3/4 width Super soft rears is #9805476 and there were also full width but I don't have that number handy.
The Super soft compound, like the premounts and the 84095 is MUCH softer than the HBR Soft and of course the HBR Mediums.
Again, the 84095 is money $$$$$
F N CUDA is offline
Old 02-14-2010, 07:40 PM
  #952
k_bojar's Avatar
Trader Rating: 30 (100%+)
since you're all talking about rubber tires - has anyone tried the HPI F10 tires on their F103??
Aside from the hex setup in the front of the F10, how well do these tires work and can you mount them on the F103/F104 rubber rims?
k_bojar is offline
Old 02-15-2010, 12:15 AM
  #953
alana07's Avatar
Like new!
thanks for the input, i would like to try out your superions but i'm too far away from your location and the shipping costs will kill off the deal.
alana07 is offline
Old 02-15-2010, 12:32 AM
  #954
That sounds about right...that would be a super soft HBR though...both the front and the rear have the blacked out double star on them indicating a HBR tire.
InspGadgt is offline
Old 02-15-2010, 12:36 AM
  #955
I'm pretty sure they are a HBR tire...what specific softness I don't know. Probably super soft as the poster above states. Both front and rear have the blacked out double star which Tamiya uses to denote the HBR tire. They wouldn't throw just any old tire in on a special edition car. Tamiya generally uses their best stuff on special edition cars.
Old 02-15-2010, 01:24 AM
  #956
Blueman Austria's Avatar
Hy There!
Just build my lod F103 boy new up, for a local race event here in Austria.
We ran 17,5T BL with Lipos. Everything else is free.
Enjoy the pics of the car:
Tamiya F103 Forum-140220101125.jpg Tamiya F103 Forum-140220101126.jpg Tamiya F103 Forum-140220101127.jpg
Thr Track:
Greetz Blueman
Blueman Austria is offline
Old 02-15-2010, 10:50 AM
  #957
zpmhinojosa's Avatar
Default Fun new vid.
2-14-10 testing out a new track.
+ YouTube Video
zpmhinojosa is offline
Old 02-15-2010, 10:51 AM
  #958
Originally Posted by Blueman Austria
Hy There!
Attachment 555466 Attachment 555467 Attachment 555469
Thr Track:
Attachment 555470
Greetz Blueman
That car looks hella cool.
Old 02-16-2010, 04:02 AM
  #959
k_bojar's Avatar
anyone know where I can get the rear gearbox for the 15th anniversary car?? also known as the F103GT gear box? part number 51243
I went thru all my 'usual' people overseas (stella hobbies, rcmart, rc-model, rc market, and percisionrc) and plain outta luck...even Tamiyausa and tower don't have the part in stock...even ebay don't have the part listed
anyone else have an idea?
k_bojar is offline
Old 02-16-2010, 05:57 AM
  #960
j.d.roost's Avatar
Trader Rating: 32 (100%+)
Originally Posted by k_bojar
anyone know where I can get the rear gearbox for the 15th anniversary car?? also known as the F104GT gear box? part number 51243
Not sure.
I know that f103 with the rubber trg tires that ran last Sat. (that guy was super fast!) had f104 l/r rear pod plates on it. So I would think you can get away with them. I am running the 3racing rear pod (side and rear wing plates) in my 103.
I might be going back to the plastic stuff (just keeping the motor plate) to save some weight.
On a side note... My car is still tweaked and hooking bad! I tried to run a few practice laps last week and could not make a lap without it spinning out.
Going to replace the t-plate this week.Hope it fixes things.
j.d.roost is offline
