1/12 forum
I'm looking at getting into 1/12 onroad after racing oval pancars for the last 5 years. Trying to figure out what I need to get, right now it's between the Associated 12R5.1 and the CRC Gen XL. I'm going to start out in the 17.5 Single Cell class, so any advice on gearing, tires, cars, and bodies would be appreciated.
Thanks in advance Michael
THAT BATTERY CALLS FOR CHARGING IN A 2CELL MODE AT 10.6 AMPS? is that safe? and would that icharger u sell there be able to do that. i currentlly use the cheap ice charger, as im new to lipo, time to step it up now...
2C stands for 2 times the capacity, in other words 10.6 Amps. (On a 1 cell (1s) charging program ofcourse)
The Ice charger won't have a problem with the 5300 battery - the 2C rating means that it can be charged safely at charging rates up to 10.6 amps. However, you must set the charging profile for 3.7 volts, not 7.4; otherwise, your new battery will never see the track.
If you already have the pack, then consider a regulator if you have any problems. There doesn't seem to be any rhyme or reason why some people have no problems, and others do. HTH
OK,SO WITH THE ICE I CAN SET IT AT 2C and get the 10.6...but again setting at 3.7 volts...what does this do charges faster? better performance as well?
Don't try to trick the ICE just to charge a little bit faster, or you'll smoke your 1s pack.
Thats what i thought, and how i previouslly been rule of thumb charging, but i keep seeing this amped up rate, and besides charging faster, i want to know if there are any performance gains to be had. TQ racing recommends, rc market had it posted, so most likely smc even recommends it? Cause if it were to gain in performance, id sacriface some lifetime of the pack, for more performance, and id have to buy that icharger, as the ice is not capable as stated..
The only gain you'll see might be more track time due to decreased charging times. However, the downside is a decrease in the pack's lifespan. There are no performance gains associated with increased charging rates.
Cool thanks, you just saved me some money on a new charger, and a possible smoked pack, ive been playing it safe doing the 4.9 charge rate with the older 4900 mah with no problems, just after seeing that wanted to make sure i was up to speed, but after your guys help, i see no reason to do it. THANKS GUYS!!!
2991Likes
