receiver antenna  replacement >
Old 09-18-2009 | 03:49 PM
  #16
RonF's Avatar
My antenna is missing out of my sr3000. where is it attached? Does it solder to J2 on the top board, directly under the exit hole? any pics of your install? My rx works, just range is only 30' or so.
Help!!!
RonF is offline
Old 09-19-2009 | 05:33 AM
  #17
sandrixx's Avatar
Default Try this
Help!!!
Bradir, try to open your rx. You'll see the how it was attached and i think you can buy replacement antenna from online rc shops. I've had serious range issues before. Now solved after buying a new antenna. Just be really careful with your rx when doing this action.
sandrixx is offline
Old 09-19-2009 | 12:07 PM
  #18
RonF's Avatar
I did open it up, but thats why i asked if it was J2 on the board. Since that is directly under the exit hole on top of the case. But i did not see any solder, broken or otherwise on the board...
RonF is offline
