Radio Control Hobbies & Raceway - Waterbury, CT.
#6571
http://www.dynamiterc.com/Products/D...ProdID=DYN2806
http://www.dynamiterc.com/Products/D...ProdID=DYN2825
have Mark order you these...
#6573
#6575
KYOW5199-70 Kyosho RT5 Front Shock Springs #70, 55mm (2)
KYOW5199-75 Kyosho RT5 Front Shock Springs #75, 55mm (2)
KYOW5205W Kyosho RT5 Rims F/R 2.2, White (2)
KYOW5205Y Kyosho RT5 Rims F/R 2.2, Yellow (2)
KYOUM551 Kyosho RT5 Main Chassis 32.95 In Stock
KYOUM552 Kyosho RT5 Rear Drive Hub Set 6.50 In Stock
KYOUM553 Kyosho RT5 Suspension Arm Set 8.95 In Stock
KYOUM554 Kyosho RT5 Body Mount Set 5.95 In Stock
KYOUM555 Kyosho RT5 Front Shock Tower 5.95 In Stock
KYOUM556 Kyosho RT5 Rear Shock Tower 6.95 In Stock
KYOUM557 Kyosho RT5 Front Body Mount Base 4.95 In Stock
KYOUM558 Kyosho RT5 Battery Hold Down Plate 5.95 In Stock
KYOUM559 Kyosho RT5 Front Wheel Shaft (2) 4.95 In Stock
KYOUM560 Kyosho RT5 Universal Rear Drive Shaft Set, 84mm 39.95 In Stock
KYOUM560-01 Kyosho RT5 Universal Rear Drive Shaft Bone (1) 10.95 In Stock
KYOUM560-02 Kyosho RT5 Rear Wheel Shaft Set (1) 16.95 In Stock
KYOUM561 Kyosho RT5 Hinge Pin Shaft, 39.5mm 8.95 In Stock
KYOUM562 Kyosho RT5 Wheel Release Spring (2) 4.95 In Stock
KYOUM563 Kyosho RT5 Wheel Release Cam 9.95 on order
KYOUM564-82 Kyosho RT5/RB5 Spur Gear, 82T 48P 4.95 In Stock
KYOUM565 Kyosho RT5 S-10 O-rings, 9.5 x 1.5mm (10) 4.95 In Stock
KYOUMB51 Kyosho RT5 Blaze clear Body 29.95 In Stock
KYOW5198-01V Kyosho RT5 Velvet Coated Threaded Shock Body, 46mm (1) 12.95 In Stock
KYOW5198-60 Kyosho RT5 Rear Shock Springs #60, 75mm (2) 6.95 In Stock
KYOW5198-65 Kyosho RT5 Rear Shock Springs #65, 75mm (2) 6.95 In Stock
KYOW5198-70 Kyosho RT5 Rear Shock Springs #70, 75mm (2) 6.95 In Stock
KYOW5198V Kyosho RT5 Velvet Coated Threaded Shock Set, 46mm (2) 49.95 In Stock
KYOW5199-65 Kyosho RT5 Front Shock Springs #65, 55mm (2)
Mark this is a full parts list with numbers from stormerhobbies.com
#6576
sweet Raul , thank you
mark , RCHR , i would like a set of those that Raul posted and one of these HUD125040 - Hudy US Standard Allen Wrench (0.05" x 120mm) . something about the spring steel i just like and i seem to go through a bunch of those small ones alot
thank you Mark
thank you Mark
#6577
I think the gauge is the wrong size.
I'll try soldering the bullet connectors to the ESC...
#6579
Hey Mark:
I know a while back you said that you guys were going to make a video with coverage from the Regionals and sell the DVD. Don't know if I missed this or you killed the idea, just wondering.
Thanks.
Thanks.
#6585
I might extend the wheelbase on my RC10T and make it an SC truck... all it'll take is an extension plate, some SC wheels/tires and a body....
There's a couple of guys that have gone the hard way, and welded two 10T chassis together, one guy even made a longer custom chassis.
I just want to do it as simple as possible, so that when the VONATs come around, it's an easy conversion...
21Likes
