What temperature do you run in cold weather(winter)?
#16
corvettecrazy i wish you the best of luck with this engine. This is the worst thing that can happen to an RC racer. It overheats very easy, doesn't have any power at all and has a one needle carb so the first thing to change in your car should be that engine
#17
Originally posted by corvettecrazy
what kind of plugs are the best in the cold weather?
i'm running a .15FE (pittiful engine I know)
#19
Originally posted by Slotmachine
A hot plug works well in just about any aplication, when you set the bottom end needle rich like it should be you need a hot plug to regain the correct fuel burn to get your punch back.
