Muchmore silent charger PROBLEM >
Old 07-19-2009 | 10:21 PM
RC TTwins's Avatar
Default Muchmore silent charger PROBLEM
I purchased a much more silent charger d/c and i have had it less that a year and it works fine except for a little problem with it. When i first turn the charger on the fan sounds very strange and is extremely loud opposite of the name. I have looked about opening it but cant get it open and don't want to break it. What would u guys recommend doing.
Thanks DJ
RC TTwins is offline
Old 07-20-2009 | 12:51 AM
It's probably a stuffed bearing in the fan housing. It will get out of alignment, vibrate like buggery making that noise, then usually align itself after it gets up to speed. I'm not sure if they are user replaceable.
To get into the box, undo the screws, then pull apart the grommet arrangement holding the plugs in the back of the case (I think by memory you twist a screwdriver/knife between the two molded parts of that), then lift the top off and unplug the wire from the LCD display to the PCB, and you're in
JR007 is offline
