DX3S and HS635 issues? >
Old 07-17-2009 | 06:37 PM
forwardonly's Avatar
Default DX3S and HS635 issues?
I just purchased a DX3S and I really like it, however, I am having a curious servo problem. I am using a HS625 on my XXX-t MF2 for steering. It all works fine in normal driving conditions, but if I put the truck on the bench and move the steering to full throw in either direction then let go of the steering wheel, the servo doesn't center and kind of flutters until it finds center again. I can move the servo left to right full throw to full throw fast as I can and there are no problems, it is only if you let go of the wheel and it snaps to center.
Any ideas on how to fix this?
Thanks,
Derek
forwardonly is offline
Old 07-18-2009 | 08:21 AM
sickpuppy1's Avatar
It looks like, from the specs on the servo, it is not meant for that fast of input signals. Probably causing confusion between radio and servo, or throw the receiver into the mix and it is just taking time to get its act together. Best thing I can suggest is to, Dont do that! LOL
sickpuppy1 is offline
Old 07-18-2009 | 06:03 PM
Since it is fine under normal use, I will use it until I get a faster servo or find it to be problem.
