Need Help
Old 07-10-2009 | 02:28 PM
Truck_Buster's Avatar
Default Need Help
I have a LRP SXX and a Vector x-12 5.5 in my t4 rtr with stock pinion and spur gear. What kind of temps should I be running at for the speed control and motor?
Thanks, Dan
Truck_Buster is offline
Old 07-10-2009 | 04:58 PM
Im not sure what the stock pinion is....maybe 20/87? Anyways I always have the best luck with my motor around 130F. Speed control is usually 110-120F. Of course this will vary with the type of running you do. Generally I always stop running if I see 175F, as I think long term damage can start to occur.
burnineyes is offline
Old 07-10-2009 | 06:31 PM
thanks the stock pinion is 19 I'm gomma go down to a 15 because the speed control gets pretty warm.
