Serpent 966
#631
That's what i mean with "2/3"
These packs:
These packs:
#632
thats the pack. seems a small 10 min break, you know, walk away, dont think about it. then get back to it, and move it this way and that way, and presto, it works. ahahaha. very small tolerances, but it doesnt rub, and brass tray fitted. maybe the Angle of the Dangle, and tilt ya head that way seemed to work all good, cheers though. i had many problems with the carbon tray, and novarossi engines, as well as the Engine mount. the Sirio (capricorn) must sit a bit higher up in the carb area.
#634
Well, never mind, you solved the problem.
But isn't it a bit overdone, AND a normal battery, AND a brass tray?...
#635
well i can take my 40g of stick on weight off. if im still 30 or 40g its ok. untill the grip comes up on the track, it may just be that little bit better earlier on.
just trying it out, no harm to see how it effects the car. thanks M7H, i can always put the carbon tray back on, not a big job.
#636
Any US store get the orange belts in yet? I stripped the front belt on my 966 and was going to pick up a few sets.
#639
#640
Enjoy your 966!
#641
#642
#643
#644
gday guys,sorry to annoy you once again,silly question for you,i was going to start my build this weekend and i was wondering about the grease im using,ive got kyosho one way bearing grease to use,is this the right stuff,i thought it would actually be more like oil??sorry again for the stupid questions,cheers,
burty.
burty.
#645
burty.
burty.
