O'Donnell TGX1 Temp. Gauge >
Old 05-11-2009 | 09:32 PM
JonNBR's Avatar
Default O'Donnell TGX1 Temp. Gauge
Whats up guys. I just went and got a temp. guage so I can accurately tell the temp of my CC Sidewinder 5700. In the manual I see an 'Emissivity' setting. I`m just wondering if I should keep the default setting of 1.00 to accurately read the temp of my motor? I believe this particular guage is intended for nitro engines, anyone else using it for electronics?? Thanks
JonNBR is offline
Old 05-12-2009 | 05:36 AM
Not that particular one, but mine also is adj for emissivity. I've found the default is the best all around setting since I'm using it on a variety of surfaces - nitro plugs, batteries, lipos, esc, motors etc. If you are only doing one surface, can maybe adj it to make it more accurate (if its not), but have to have someway to calibrate. Thats the prob. If you've got a friend with a better or diff gun, maybe get an idea on how yours is reading. I used a Raytec for comparison and left emissivity alone after seeing it compared pretty good to the better temp gun.
I have that system too, Sidewinder/5700 and esc has never been over 140F, motor though likes to run around 180F.
Duster_360 is offline
Old 05-12-2009 | 06:18 AM
racer1812's Avatar
Super Moderator
I have the TGX1 and I have mine set at the default which actualy reads 100 on the screen. I've checked it against other temp guns known to be acurate and never had a difference of more than a deg. Be cautious with shiny surfaces though, like Novak BL motors. Never had an issue with shiny surfaces but it's possible. Mine is "dead on" with my green Castle motors though.
racer1812 is offline
Old 05-12-2009 | 02:53 PM
JonNBR's Avatar
Cool. Thats about the same as my motor. 170-185, depending on the weather outside. And I do fool around with other things with it too, so I guess I`ll leave it alone. Appreciate it guys
JonNBR is offline
Old 05-12-2009 | 04:47 PM
Same here - tried 3 diff pinions and 2 diff spurs - no real diff. I'm going to try running a Medusa/MM and 3S and see if I can manage temps with that setup.
Old 08-27-2011 | 12:02 PM
Andrew_67's Avatar
My temp gun only reads Er5, i can`t get ride of it. I changed the battery......any idea`s ??
Thanks !
Andrew_67 is offline
Old 06-29-2012 | 03:46 PM
fordman86's Avatar
Anyone ever figure out the ER5 code for this unit.
fordman86 is offline
Old 09-17-2012 | 01:26 AM
luke71933's Avatar
Hey, can you tell me if the built in stopwatch can measure lap times, like when i pass through the finish line and then press a button and stores that number and then it rests to 0:00 and stars again so when i pass finish lien again i do the same thing?
luke71933 is offline
Old 09-17-2012 | 07:25 AM
racer1812's Avatar
Super Moderator
IIRC it just stops and then starts again, not logging each lap time.
Old 09-17-2012 | 11:20 AM
luke71933's Avatar
I knwo it cnat log lap times but will it be fast enoguh to start and stop and reset for evry lap or will i Hv to only calculate 4 out of 8 laps because It wont be fast enoguh to reset form the lap time before?
