MRX-4X
Old 05-07-2009, 05:13 PM
  #871
Originally Posted by CanyonCarverR1
I use shoe-goo and have never had a failure, but I don't use a ton of breaks.
Thanks for the info will try it this weekend.
ChartRacing is offline
Old 05-07-2009, 05:27 PM
  #872
Default Clutch
I run a 4-shoe clutch in my 4R and my son runs a 3 shoe in his 4X. I find the Orion works best in the 3 shoe clutch you can set it up very aggressive.
Old 05-07-2009, 10:36 PM
  #873
@Sohlman and Mike Strack
Thanks a lot for your feedback. Will give the 3-shoe type a try...
Btw, which spring, shoes and gaps do you use?
@Wingracer
Please tell us your secret or PM it to me at least
fulcrum2 is offline
Old 05-08-2009, 09:38 AM
  #874
Ron C.'s Avatar
@Wingracer
Hello fulcrum2,
With the MSR Clutch Spring and the Mugen Yellow Clutch Shoe:
On a 4D Clutch set up: Put on 10.2 mm (and dial in from there)
On a 3D Clutch set up: Put on 9.4 mm (and dial in from there)
Measure it from the tip of the crank to the flat surface of the clutch spring nut.
Ron C. is offline
Old 05-08-2009, 11:01 AM
  #875
Thumbs up
Thanks a lot Ron!
Regards, Stefan
fulcrum2 is offline
Old 05-08-2009, 02:14 PM
  #876
wingracer's Avatar
Trader Rating: 24 (100%+)
Originally Posted by Roelof
The Orion square spring does add a little bit something different
For the inner bearing I use the one with a flang as the side belt tensioner does.
Oh yes, our own red shoe,
Damn Roelof, quit giving away all my secrets.
wingracer is offline
Old 05-08-2009, 09:04 PM
  #877
asw7576's Avatar
I think it's everyone little secret now
Roelof : the fifth one on the right is titanium clutchbell. Very nice.
asw7576 is offline
Old 05-09-2009, 06:18 PM
  #878
TommyBlazin's Avatar
Trader Rating: 29 (100%+)
can you run that bearing on the 4d with same results?
TommyBlazin is offline
Old 05-09-2009, 06:49 PM
  #879
wingracer's Avatar
Yes.
Old 05-09-2009, 11:27 PM
  #880
Guys, what´s so special about this bearing? I understand that the spring can make a difference, but how does the bearing improve the clutch? Is it Mugen H0603 5x10 flange?
Thanks, Stefan
fulcrum2 is offline
Old 05-10-2009, 07:16 AM
  #881
MugenDrew's Avatar
Trader Rating: 36 (100%+)
It eliminates some shims between the fly wheel nut and the rear bearing.
MugenDrew is offline
Old 05-10-2009, 01:22 PM
  #882
wingracer's Avatar
It doesn't effect performance, just reduces the shims needed to set it up.
Old 05-10-2009, 02:15 PM
  #883
Because the flang the bearings are placed a tiny bit further from each other which lowers the sideway play. But indeed it minimized the needed shims.
For those who have used many axial bearings, keep the steel plates and use a brass ring 10x5mm as gliding bearing, nor more failing axial bearings for sure!
These brass rings can be found in any hardware store, 10 for a dollar....
Roelof is offline
Old 05-10-2009, 04:26 PM
  #884
wingracer's Avatar
I like that idea but I haven't blown a thrust bearing since the one that came with my first MRX-3 died. Proper maintenance and they last forever.
Plus, 5x10 brass washers may be common in Europe but I doubt many US hardware stores have them.
Old 05-10-2009, 06:50 PM
  #885
CanyonCarverR1's Avatar
Trader Rating: 13 (100%+)
[QUOTE=wingracer;5794660]I like that idea but I haven't blown a thrust bearing since the one that came with my first MRX-3 died. Proper maintenance and they last forever.
+1
CanyonCarverR1 is offline
