which power supply?
Thats an 80watt charger, so the power supply needs to be at least that amount and prob more to deal with the inefficiency in the charger. I'd look for a 100watt power supply which is not a lot as power supplies go. The charger says it will charge at 10amps, so that wopuld be minimum rate.
I tend to buy things like this a little bigger than they need to be, that seems to work best. This would work -
http://www.amainhobbies.com/product_...oducts_id/5172
Better -
http://store.buyreliant.com/servlet/...Pyramid/Detail
Better -
Basic Eqtn - Power(watts) = volts x amps. With power supplies, need to look at the supply to find actual voltage - my Radio Shack is 13.8v and 25amps, so its rated power - 13.8 x 25 = 337.5watts.
My other PS is a ProPeak 20a supply and its also 13.8v but 20a, so its only 276watts. Both of these are switching type supplies versus transformer based PS and its prob prudent not to push these to 100%. Most I've ever done with these is charging 6S a123 pacs - 21.6volts at 10amps => 216watts. Switching supplies have rep for quiting under high load.
Something to consider if you're close on power with a PC supply.
