1/12 set up guide >
1/12 set up guide
1/12 set up guide
Old 02-27-2009 | 07:29 AM
evirobs's Avatar
Thumbs up 1/12 set up guide
I have attached a 1/12 set up guide for all newbie like me.
The informations are mostly gathered from posting in RCtech.
If i made any mistake or left out any important tuning guide, i hope the experts out there will highlight or amend the file & repost.
Hope this will be a bible for all 1/12th racers....
File Type: doc
evirobs is offline
Old 02-27-2009 | 07:37 AM
Ricky/C's Avatar
Dude thanks a lot! Yhis is great This weekend will be my first 1/12th race!
Ricky/C is offline
Old 02-27-2009 | 08:21 AM
Very well put together. Way to Go.
P.s> This should be pinned (hint, hint)
jdeadman is offline
Old 02-27-2009 | 08:41 AM
PitNamedGordie's Avatar
Nice! I think this will be good for WGT cars too...which I plan on getting into.
This is a good reason this site needs a wiki style page...
PitNamedGordie is offline
Old 02-27-2009 | 10:54 AM
2056dennis's Avatar
Default 12th setup
hey guys you can also go to this site for help on your 12th scale setup
http://richardchang.com/hobby.php?topic=112setup
2056dennis is offline
Old 02-27-2009 | 08:58 PM
evirobs's Avatar
Yes, Richard Chang site provide some great insight. I have already included his portion & more on the 1/12th guide...
evirobs is offline
Old 02-27-2009 | 10:00 PM
CCH1978's Avatar
I love it!!!
CCH1978 is offline
Old 02-28-2009 | 10:20 AM
tpczx6's Avatar
TTT
tpczx6 is offline
Old 02-28-2009 | 10:25 AM
evirobs,
would you mind if I put a copy of this up in the 12th section of http://rcpedia.wikidot.com/ ?
Some really useful info there !
chris_dono is offline
Old 02-28-2009 | 12:03 PM
wingman2's Avatar
Yeah, cheers for that mate, very helpful indeed!
wingman2 is offline
Old 02-28-2009 | 12:32 PM
Trips's Avatar
Nice job on the guide... If I can make a suggestion, I'd think it would be appropriate to put a citation in the document giving credit to Rich Chang for the portions that came from him...
just a thought...
Trips is offline
Old 03-02-2009 | 06:15 AM
nitro psyco's Avatar
this is a very helpful users guide Thanks
nitro psyco is offline
Old 03-03-2009 | 11:18 AM
YmeBP's Avatar
Thanks!!
YmeBP is offline
Old 03-03-2009 | 12:41 PM
This is awesome...thanks for the hard work.
Here is what I would suggest to add onto that doc file....I am always have trouble remembering what final drive/roll out to use on different motor speed. Right now...I am not so sure how many ppl are still running brushed motor, so I think it can be very general about those motor. But for brushless motor, can that be listed motor like 21.5, 17.5, 13.5, 10.5 and mod?
I know alot of ppl are running 17.5, 13.5 and even 10.5...those who run MOD probably don't need to know about that cause they are already PRO. But what is the typical tire size (front and rear) and what final drive with roll out calculation with all these motor 10.5, 13.5 and 17.5?
I would say, just give us the general cause ppl will say different brand of 13.5 will perform differently, but with the basic gearing, at least we are not going to run something way under or way over.....at the end, we will all do the final testing at the track.
Here, I have something I saved in my phone just incase I have some pickup race for 12th scale
(27T/19T brushed stock motor) 1.7" front tire, 1.75"-1.8" rear tire (diameter)
Purple front (42s) Grey rear (30s) (probably is old news cause they are all running something with different color now with Parma and Jaco)
1.90" roll out
Droop 0.5mm-1mm
(13.5 brushless motor) 1.63" front 1.73" rear (diameter)
Double pink front, yellow rear (new color - current model)
62-65mm roll out
Just a suggestion...............
Solara is offline
Old 03-03-2009 | 06:04 PM
evirobs's Avatar
This is the gearing file i use.
You just need to change the spur gear sizing to get the roll out.
Normally, i will up 2 pinion size for every change in motor-turn for a start.
example - if i am using 20pinion for 10 turn motor, i will change to 22turn for 11turn as a start out. Further fine tune during the run.
Also, I kept a copy of the roll-out for various common spur size as a reference.
Hope this will be useful.....
File Type: zip
evirobs is offline
