Noob to Lipo?
Old 02-12-2009 | 09:08 PM
moose2851's Avatar
Default Noob to Lipo?
Hey I hope to find some help I just purchased a Thunder Power 1010c charger, 14amp power source the tp 210v balancer.
My questions are: is it true you can charge two packs at once if so HOW?
As well I purchased SMC Lighting volt 7.4V 5000mAh 28C Hard Case LiPo's as a cheaper alternitive to thunder power batteries but the balance plug is different are there adapters to plug E flite balance end into Thunder power balance board?
Thanks for any help with this.
moose2851 is offline
Old 02-13-2009 | 05:56 PM
moose2851's Avatar
bump
Old 02-13-2009 | 09:09 PM
helibrian's Avatar
To charge/balance 2 packs at once you will need to make a "Y" harness that will effectively wire the 2 packs together in series through both the balance leads and the main power lead. Then you would charge/balance your two-2s1p packs as if they were one-4s1p pack. I think Robert Green has an article demonstrating it on his DIY site. His article describes two-3s1p packs but translating it to two-2s1p or even three-2s1p packs, is just a matter of common sense. Google 'Robert Green DIY' or something like that.
Align to TP balance adapters are available all over the net and probably available at your local hobby shop as well.
helibrian is offline
Old 02-14-2009 | 12:09 AM
Jason Pelletier's Avatar
For a NOOB to lipo you got some great stuff !!! Rock'on with ya bad self.
Jason Pelletier is offline
Old 02-14-2009 | 06:15 PM
moose2851's Avatar
Thanks for the help with this I hope to be up and running soon
Old 02-15-2009 | 02:36 PM
http://www.rbgrn.net/blog/2008/07/ho...ngle-6s1p.html
Duster_360 is offline
Old 02-15-2009 | 02:49 PM
helibrian's Avatar
Yeah! That's the one.
Old 02-15-2009 | 09:28 PM
moose2851's Avatar
Thanks again keep it coming anyone know where I can get a converter for jst to tp balance connector having trouble finding one there are lots going the other way??
