Best Battery for starter box?? >
Old 01-14-2009 | 07:47 PM
RGraves's Avatar
Default Best Battery for starter box??
I have a 12v gel cell in my Losi starter box but it doesnt seem to give it a enough to really bump the flywheel. What batteries are you guys using???
RGraves is offline
Old 01-14-2009 | 07:58 PM
rearviewmirror's Avatar
Two Pro-Tek 2S 15C 4000mAh batteries in series make an excellent starter box setup. (They're $35/each.)
rearviewmirror is offline
Old 01-14-2009 | 08:30 PM
t0adman's Avatar
I've been battling with the heavy ass 12v gel cell that barely gets the job done and my buddy just got a 2200mAh Reedy lipo that makes that starter box roar! If you have or are willing to get a lipo charger the lipo battery is the way to go.
t0adman is offline
Old 01-14-2009 | 08:34 PM
OvalDude99's Avatar
Originally Posted by t0adman
I've been battling with the heavy ass 12v gel cell that barely gets the job done and my buddy just got a 2200mAh Reedy lipo that makes that starter gox roar! If you have or are willing to get a lipo charger the lipo battery is the way to go.
I will have to agree. I was using 2 old 1400 nicads and switched to a 14.4 lipo and WOW what a difference.
Just so you know, I am using an ofna chrome top box to start a Mammoth st with the stock 24.7 motor and it works great.
OvalDude99 is offline
Old 01-14-2009 | 08:58 PM
screamin' eagle's Avatar
My 12v wouldn't even turn over a brand new Macstar 28 - I went to two 6c nimh packs (cheapie Hobby People 2400 packs, $17 each) and it made a world of difference.
screamin' eagle is offline
Old 01-14-2009 | 09:05 PM
Allumina's Avatar
idk if im just lucky or what, I run 12volts gelcells in my truggy boxes and they turn over my high dollar, high compression RB's like no ones business...even when they were brand new, never an issue.
I will agree that lipos will be the best though, i just prefer my gelcells because i never have to charge them, and they're way cheaper, and i dont mind the weight.
Allumina is offline
Old 01-14-2009 | 09:12 PM
spider timmy's Avatar
i know losi makes some 4 cell lipos made specifically for starter box idk on there performance but i can imagine they would be pretty good http://www.horizonhobby.com/Products...rodID=LOSB9821
spider timmy is offline
Old 01-14-2009 | 09:34 PM
Integra's Avatar
Gel cells are cheep...but so are lipo's...you just have to know where to shop for em.....Ebay is your best friend when it comes to cheepo lipo's.....4 cell's go from 25-100$ 2200mah-8000mah.....i use a 2200 and dont even think about charging it for a weekend of racing....ill check it after but they usually go for at least a couple weekends...and they have 5X more power then any Stick pack could dream of having...THE only thing you have to watch out for is the C rating....DO NOT buy any battery with less then 20C....they will not have the punch and will feel like a 1/2 dead stick pack....if anything get a 25C pack to be extra safe.....just search 14.8V lipo in ebay...should pull up lots.
Item # 260345716573
thats the cheepest good pack that's on the bay currently.
Integra is offline
Old 01-15-2009 | 07:02 AM
I use two cheapo 3600's in my losi box. One thing to look at is that inside the losi box has a lot of tamiya type connectors. Get rid of all the connectors yuo can and either straight wire or use these:
http://www.carolinasrc.com/Webstore/...idcategory=504
Just a dean type connector. This will suprise you how much more effecient your box works for you.
ABURTON is offline
Old 01-15-2009 | 07:11 AM
wallot's Avatar
4S LiPo (14.8V) is the way to go. You can get tons of cheap LiPo pack all over asia stores like unitedhobbies or through ebay.
LiPo is light and gives way more punch than NiMh.
I use Zippy-H 5000mah pack in my truggy box and True-RC 8000mah pack (actually made it from left over cells) in my buggy box. Both are little bit overkill as any decent 2000+mah will do, but at least I can charge them once a month.
I am done with NiMh as they just have so high self discharge rate.
The only NiMh I am ok with are in Glow Ignitor as my 3S LiPo powered powerpannel sometimes does crazy things.
wallot is offline
Old 01-15-2009 | 07:32 AM
PTP Racing's Avatar
I almost ordered a lipo for my starter box but I usually leave my box on pit road and I figure it would be safer to use stick packs so someone doesnt run the lipo pack dead by mistake.
PTP Racing is offline
Old 01-15-2009 | 07:38 AM
+1.......
I rewired my last losi box with some deans noodle wire and then added deans plugs with a set of 3300mah nimh stick packs and the box would turn over a brand new C6 with no problems......
MattP is offline
Old 01-15-2009 | 07:46 AM
Integra's Avatar
Originally Posted by MattP
+1.......
Now toss in a 4 cell ....and you'll crap you pants with all the power.
Integra is offline
Old 05-01-2012 | 12:29 PM
wriffwraff's Avatar
wriffwraff is offline
Old 05-01-2012 | 01:06 PM
Integra's Avatar
Originally Posted by wriffwraff
There are MUCH cheaper alternatives than This.
Hobbyking is 1/3 the price for a comparable 5000mah
Integra is offline
