Team Losi JRXS Type-R
#8536
Here is where I get my logic. I know it is Xray, but it is more about the set up theory. Page 24 I think it talks about Roll Centers and Center of Gravity. Check it out, This has pretty much always made my car do what it claims.
T2 Set up book
http://www.teamxray.com/teamxray/pro...09%20US%20Foam
RedRocket
T2 Set up book
RedRocket
#8537
T2 Set up book
RedRocket
T2 Set up book
RedRocket
#8538
Read this about three years ago. Gone by it ever since. I believe the RC is one of the most aggressive changes that you can make. If you are traction rolling, this is what you change. If you are washing out in the middle of the corner, this is what you change. It is very important to get the RC good. Spend a day doing nothing but RC changes and see what you like. It is real good to know. Hopefully your car chages easily.
RedRocket
RedRocket
#8539
Hey guys thank you for your good replies. I tested with roll center a little more and found that the with high front and low rear is very good combination for outdoor asphalt and I think I will stick with this.
Now i do have another question: I have a problem with the car rear end becoming unsettle when flying thru sweeper after a straightaway. For some reason in high speed corners like sweeper, I have to let off, because if I dont, the rear end of the car gets loose, which I dont know why. Instead going thru big sweeper at full throttle like most other guys, I have to let off and use only 3/4 throttle. Some guys tell me it's because rear is losing contact with ground because I have little droop? I use 2mm droop above ride front and rear. Why is the car doing this and how can I fix it? thanks guys
#8540
A car being loose there are probably 6 or so adjustments that you can make to the car. The droop they might be refering to is actually the front cause you are under power going into the sweeper. If you allow the front of the car to rotate more weight to the back of the car it might help a little bit. The idea would be to get more camber gain in the car without allowing the car to transfer too side to side weight too fast. You can start with upper camber links and lowering them on the tower or adding shims to the hub. If the car is becoming irratic I would check my shock oil. Make sure you don't have too much oil in the shock to where you have created a pack feel in them. This is when the rebound just shoots back out. If your shock are packed this can cause a really bad side to side ittatic feel. They should just rebound nice and slow and smooth. Most guys only run about 50% rebound in there shocks. Also try a 50 or 60 weight oil to slow the weight transfer of the car, if the grip is atleast medium. Try some of this stuff, also check out the link that I posted up above for the setup book from Xray.
How are the Losi's doing in Cleveland?
RedRocekt
#8541
i just got an new kit and i canht get the diffs to go toghether.i built a kit last year about this time and had no problems with it.some of the guys that have built new kits tecently warned me that the diff spring is to long and wont let it screw toghether.so after looking at it i noticed that if i just try to put the diff screw in the hub that the screw is not even long enouph to reach the other side...looks like i will need about a 1/4 inch...
any ideas on why they are like that?
#8542
#8543
They could have packaged the wrong screws in your kit. People have made claims they either got wrong parts or are missing parts in their kits. Contact Horizon and get it taken care of.
#8545
The spring should be a short silver one, if you have a longer black one it is the wrong spring.
#8547
The springs in my recent kit were the same. A longer black as opposed to the short silver. The long black is for the genII offroad diffs I believe, but the one you need is the same as used in the xxx-cr diffs.
#8550
I'm after a setup ofr linoleum (kind of plastic, used on old indoor basket field ... figure it at http://www.armstrong.com/resflram/na...-linoleum.html)
Tyres are mandatory Schumacher Dragon 24mm.
Any body has an experience to share?
Last time I raced there with a Cyclone, I was a soft as possible...
